It is currently Sun Oct 04, 2026 4:54 am
 Post subject: Shade Tone Tint Generator
PostPosted: Sat Sep 08, 2012 12:15 am  (#1)
So I've decided upload some of the files I created to help generate the Pencil Colour Wheel
The Palettes I already created for the design can be found here Colour Pencil Palettes
This is the gimp.xcf file that I used to determine the shade, tone and tints of each colour, I spent ages playing with the layer modes trying to get the thing working for any colour, but its working ok now.
Instructions for use
1. Download file and unzip
2. Open file in Gimp (Its the native gimp XCF format)
3. make sure you have your layers dialogue box open
4. Select the layer Named "Base Colour Shade"
5. Fill Layer with Desired Colour
6. Select Top Layer Named "Text"
7. Go Edit>Copy Visable then go Edit>Paste as>New Layer
8. You should now have a new layer at the very top with your colour, shade, tone and tint. If you select this layer, then you'll be able to use the colour pick tool (Looks like a pipette) :colpick , to get the colour you require. Simply select the tool, then left click on the colour you require and it will become your selected foreground colour.
9. If you find the text Layer annoying then you can simply turn it off by Left clicking on the little eye icon next to it in the layers dialogue box.
Hope this little file helps some of you out, although I can't garauntee it to be 100% accurate.
 Post subject: Re: Shade Tone Tint Generator
PostPosted: Sat Sep 08, 2012 2:16 am  (#2)
i read your post several times and had no clue what this was all about
then i tried it and now it all makes sense
cool idea !
PostPosted: Sat Sep 08, 2012 2:50 am  (#3)
that's cool, he4rty! could be useful for other things than pencils definitely. but i do wish you had named the colour slots differently, at least to me "shade", "tone" and "tint" have other and more specified meanings and it made your post a bit confusing. it helped a lot to look at that pencil colour wheel, though - beautiful creation :)
PostPosted: Sat Sep 08, 2012 7:41 pm  (#4)
Great idea he4rty.
I decided to create a script to reproduce this for you.
see http://www.gimpchat.com/viewtopic.php?f=9&t=5199
PostPosted: Mon Sep 10, 2012 2:28 pm  (#5)
http://espvisuals.blogspot.de/2012/09/e ... -book.html
PostPosted: Mon Sep 10, 2012 3:35 pm  (#6)
esper, you made that? :coolthup
PostPosted: Mon Sep 10, 2012 4:32 pm  (#7)
yeah, i copied and pasted the link :hehe
PostPosted: Mon Sep 10, 2012 4:48 pm  (#8)
esper: :hehe excellent copying and pasting, very impressively done ;)
