It is currently Mon Oct 05, 2026 6:18 am
 Post subject: Alien Skin?
PostPosted: Fri Sep 21, 2012 6:00 pm  (#1)
I was going for alien skin anyway. Lyle got me to thinking about using edge detect and G'mic with his recent post and this iswhat I ended up with. Not exactly what I was after but what the heck, I was just playin' anyway. Made it seemless & tileable so you can save it as a .pat file and make a pattern out of it if you like it. Makes a really bizzare desktop background.
 Post subject: Re: Alien Skin?
PostPosted: Fri Sep 21, 2012 6:03 pm  (#2)
That's interesting. I've been experimenting with creating skin textures using G'MIC>Patterns>Cracks, Edge detect>edge and using the results as a bump map. I'm not quite there yet but I think I'm on the right lines.
PostPosted: Fri Sep 21, 2012 8:47 pm  (#3)
Cool! Thank you. :)
I used the pattern on this futuristic killer robot.
PostPosted: Sat Sep 22, 2012 6:40 am  (#4)
:hehe Thanks for trying it out but it was just some goofing around. That killer robot would probably look better with some hull plate armor tho instead of my cheesy skin attempt. :rofl
PostPosted: Sat Sep 22, 2012 3:00 pm  (#5)
fun, draconian :)! and since you mention armour, here's something that her highness the queen thought would suit your new title :
PostPosted: Sat Sep 22, 2012 11:03 pm  (#6)
Now that's just weird looking!
PostPosted: Sun Sep 23, 2012 1:28 am  (#7)
:hehe you don't say! well, undying loyalty sometimes means wearing weird stuff your souvereign sends you ;) ...
PostPosted: Sun Sep 23, 2012 12:51 pm  (#8)
Feel free to try that out.
My original photo: (click through to get to the full size version)
Kevin
PostPosted: Sun Sep 23, 2012 1:39 pm  (#9)
Kevin
I use your photo a lot in examples and tests Kevin.Sorry i didn't mention it belonged to you.
