It is currently Tue Nov 17, 2026 9:14 am
 Post subject: Gradients
PostPosted: Mon Sep 27, 2010 8:51 pm  (#1)
I saw the post on gradients and wanted to provide a link to this site:
http://soliton.vm.bytemark.co.uk/pub/cpt-city/
That has many gradients in a variety of formats including gimp gradient format.
-Rob A>
 Post subject: Re: Gradients
PostPosted: Mon Sep 27, 2010 8:57 pm  (#2)
Thanks Rob, nice link. =)
PostPosted: Tue Sep 28, 2010 4:15 am  (#3)
good find Roba very good side for gradients and palettes
PostPosted: Tue Sep 28, 2010 5:18 am  (#4)
hy there is anyway to convert Paint Shop Pro gradient in gimp gradient ?
Gradient are not images but basically text files so the usual method (save the images in a intermediate format ) will not work
Maybe Solved! when there is are sample displayed as here http://soliton.vm.bytemark.co.uk/pub/cp ... scord.html
then the RobA script to sample a gradient along a path should do the trick ( the path should attraverse horizontally the image of the gradient
PostPosted: Tue Sep 28, 2010 7:41 am  (#5)
The script is available here.
PostPosted: Tue Sep 28, 2010 8:44 am  (#6)
thank O i forgot it...btw i am not sure it will work is a guess.
I have to reinstall Gurm first or add more brush and gradients will only make impossible find the right one in the mess
PostPosted: Tue Sep 28, 2010 12:25 pm  (#7)
I have the script and have used it before, but now I can't find it in my menus! I'll find it again, but it's annoying!
My Sigs = My Photos
PostPosted: Tue Sep 28, 2010 1:10 pm  (#8)
I found it! It took a while, but I did find it!
My Sigs = My Photos
PostPosted: Wed Sep 29, 2010 6:11 am  (#9)
thank for the tip !
PostPosted: Wed Sep 29, 2010 6:36 am  (#10)
PhotoMaster every time i dl a new script i keep an inventory of name and i also open the script to see where it will be in the menus, then i add that info as well.This helps me when i need to find and edit or look at a script, or even uninstall the correct one. =)
PostPosted: Sun Jan 19, 2014 1:09 pm  (#11)
Yesterday I was looking for Gimp plugins in Fedora Yumex and I found cptutils as an app for Fedora.
I went to the site and remember that I knew it.
Snooping around the site and gaining levels in the URL I found in the pub folder the existence of cptutils-online, which communicate here regarding the PhotoComix's comment about format conversion for gradients.
cptutils converts as follow:
(input:)
ArcView legend
Gimp gradient
Gimp palette
GMT colour table palette
SVG gradient
to
(output:)
CSS3 gradient
DS9/SAO colour table
GIMP gradient
GNUplot palette
Medcon lookup table
PNG image
POV Ray header
SVG gradient
The URL:http://soliton.vm.bytemark.co.uk/pub/cptutils-online/select/cpt/svg
PostPosted: Mon Mar 03, 2014 9:06 am  (#12)
Nice one
