It is currently Sun Oct 04, 2026 3:05 pm
 Post subject: Crown Mouldings Gradient Pack
PostPosted: Sat Nov 03, 2012 12:11 pm  (#1)
Crown Mouldings.zip [42.29 KiB]
Downloaded 262 times
You probably might have noticed that the goblets have all used the crown moulding default gimp gradient to get the reflection in the metal, I like the gradient for these type of things but a bit boring only having one, So I searched the net and found some moulding profiles that I have converted into gradients.
Might seem pointless to most but then realised that they would work well as picture frame gradients, so here is a quick example....
If you happen to be using the same picture frame script as I did then you need to change frame shape to smooth, see image below....
Here is a link to the Picture Frame Script
 Post subject: Re: Crown Mouldings Gradient Pack
PostPosted: Sun Nov 04, 2012 6:48 am  (#2)
he4rty: this will be useful, thank you for sharing :)!
PostPosted: Sun Nov 04, 2012 8:33 am  (#3)
Thank you, he4rty!
I love gradients, use'em a lot, d/l'ed.
PostPosted: Sun Nov 04, 2012 10:50 am  (#4)
Sample a Gradient Along a Path
Thanks, if you like gradients then this is a great little script-fu for creating them
PostPosted: Sun Nov 04, 2012 5:46 pm  (#5)
Thank You He4rty the gradients look great :bigthup
