It is currently Wed Oct 14, 2026 12:42 am
 Post subject: Picture Frame Resource Pack
PostPosted: Mon Nov 12, 2012 11:22 am  (#1)
Some of this has been posted already, some is new, I decided to put it all in one place.
Included are 22 Crown Moulding Gradients
6 Wooden Colour Palette
1 Guide Chart
Here is the guide chart
For use with Graechan Gradient Frame Script
Resource Pack.zip [552.7 KiB]
Downloaded 373 times
 Post subject: Re: Picture Frame Resource Pack
PostPosted: Mon Nov 12, 2012 11:55 am  (#2)
Thank you, he4rty!
Full package! That is a great example of team work.
PostPosted: Mon Nov 12, 2012 12:02 pm  (#3)
Thank you very much he4rty
PostPosted: Wed Jun 12, 2013 5:19 am  (#4)
How do use these gradients to make picture frames?
PostPosted: Wed Jun 12, 2013 6:59 am  (#5)
Thank you he4rty.
2-ton - you need Graechan's script. The link is in the first post under the image.
PostPosted: Wed Jun 12, 2013 9:12 am  (#6)
As Erisan said you can use the script provided by the link but gimp 2.8 seems to be having issues with selecting a gradient from inside a script and crashes.
PostPosted: Wed Jun 12, 2013 9:05 pm  (#7)
oh duh, I didn't notice the script link...thanks for pointing that out.
cron
