It is currently Sun Nov 22, 2026 2:38 pm
 Post subject: Re: Gimp 2.8.4 splash screen
PostPosted: Fri Mar 15, 2013 2:14 pm  (#1)
That is very pretty. You made good use of that splatter default brush too.
PostPosted: Sat Mar 16, 2013 6:23 am  (#2)
I like it conbagui. It's bright and cheerful and I agree with Molly about your use of the splatter brush.
PostPosted: Sat Mar 16, 2013 8:54 am  (#3)
conbagui: that's a nice looking splash screen - i like that you made it so simple and i like the colouring. and -surprise- i like how you used that brush :)!
PostPosted: Sat Mar 16, 2013 3:10 pm  (#4)
yes, the use of the brush really makes that a cool splash screen!
PostPosted: Thu Dec 14, 2017 9:48 am  (#5)
Here is some more ...
