It is currently Sun Oct 11, 2026 5:22 am
 Post subject: I created a new red flannel seamless pattern
PostPosted: Thu Apr 04, 2013 1:10 pm  (#1)
File is the smaller image below.Just save to your patterns folder. :)
2500x2500 image using the pattern.
 Post subject: Re: I created a new red flannel seamless pattern
PostPosted: Thu Apr 04, 2013 2:02 pm  (#2)
thank you Rod
PostPosted: Thu Apr 04, 2013 2:17 pm  (#3)
thank you Rod
You are welcome Molly. :)
I will be posting some more seamless textures as well.I know you guys have lots of patterns already so i am taking requests.
PostPosted: Thu Apr 04, 2013 2:57 pm  (#4)
Very nice, Rod. I love plaid and I love flannel. Unbeatable combination.
PostPosted: Thu Apr 04, 2013 3:22 pm  (#5)
rod: perfect! i love tartan and i love flannel :).
O: nice shirt! looks so cosy i wanted to pluck it off the screen and put it on.
PostPosted: Thu Apr 04, 2013 3:30 pm  (#6)
Hope you don't mind Rod but used G'MIC's Tileable rotate and strategically cropped for the resulting seamless tartan texture. Also added some threadlike texture to the mix. :)
PostPosted: Thu Apr 04, 2013 6:57 pm  (#7)
Bonjour,
Thank you for the texture :)
I tried to simulate the wear.
PostPosted: Thu Apr 04, 2013 9:58 pm  (#8)
Like the texture samj. If I have no problem with sharing anything I use for anyone here's use, but, since I used Rod's texture as base, it will ultimately be up to Rod (that's my policy; if I use someone elses work and modify it, it's that person's property as well). :)
PostPosted: Thu Apr 04, 2013 10:21 pm  (#9)
You guys can use this and any other textures i post however you wish and that includes commercially.
O i need a few of those shirts myself.
Sam and Lyle i love the changes you made.I expected a droste from you though Lyle. lol
BTW Lyle, and Sam i downloaded your changed textures to my patterns folder and renamed them accordingly.
PostPosted: Fri Apr 05, 2013 4:28 am  (#10)
Bonjour,
Thank you Rod :)
(I do not sell anything around Gimp).
When I use an image of another person I try not to forget to mention (being aged I'm sorry if I forget... ).
PostPosted: Fri Apr 05, 2013 5:28 am  (#11)
:jumpclap :jumpclap Cool pattern Rod ...never had a flannel pattern before to play with
but something weird happened with your pattern, each time i open that pattern of your with xnview it changes,
sometimes are the colours to change sometimes the shapes sometimes both
Almost if somebody was swapping the colours channels ... ;)
and then become darker
sometimes instead the change seem to be from positive to negative
i prefer the negative (i believe the "positive" become greenish because some swapping incident , negative restored colours more close to the original...
oh what happened to the negative ,now...now it seems not only a negative but also processed with fractalius
The more i look the pattern the more its geometric become unstable... as if reflected in some sort of distorting mirrors
and go on on shifting...
I start to be worried if all this happens only by opening the file with Xnview , then what may happen opening with gimp , gmic or mathmap ?
anyway sharing patterns may be a good idea :
you share 1 and you got 15...no bad :geek
PostPosted: Fri Apr 05, 2013 5:47 am  (#12)
photo comix: :jumpclap :hi5 :clap love them! so good to have you around to play with patterns again :).
PostPosted: Fri Apr 05, 2013 11:18 am  (#13)
You scared me there for a moment PC i thought the pattern had become possessed. lol
And then i saw it wasn't mine but Sams. heheh
Great to see your wonderful displays of patterns again.Hey have you done any new 3D Mandelbrot images?
PostPosted: Fri Apr 05, 2013 11:46 am  (#14)
Hy Rod glad you like i just posted the rest here viewtopic.php?f=12&t=6870&start=0 (i didn't want risk to flood here )
about Mandelbulb i have a couple of new series i should only resize ...oh thinking better i may upload also on flickr so i may get url for all sizes and spare GC bandwidth ...
PostPosted: Fri Apr 05, 2013 9:29 pm  (#15)
samj wrote:
Bonjour,
Thank you Rod :)
If someone changes anything i create i like to write their names to the new file to make sure i remember who made it better. :) So for you and Lyle's creations i now have 2 new patterns.
Samj-red-flannel-wear and Lyle-red-tarter.
