It is currently Sun Oct 11, 2026 9:13 pm
 Post subject: I believe I found your marbles.
PostPosted: Wed May 08, 2013 1:34 am  (#1)
Thought I would create a seamless texture for you all to use as you like.
Click here for the texture's deviant. :)
 Post subject: Re: I believe I found your marbles.
PostPosted: Wed May 08, 2013 3:19 am  (#2)
That's a nice one Lyle. :)
Thanks for sharing it.
PostPosted: Wed May 08, 2013 3:23 am  (#3)
Thanks Lyle
PostPosted: Wed May 08, 2013 3:38 am  (#4)
Thank you Lyle
PostPosted: Wed May 08, 2013 3:42 am  (#5)
I love it Lyle, now you have to tell your secret, how did you do it?
PostPosted: Wed May 08, 2013 5:26 am  (#6)
That's amazing Lyle! that will definitely be going in with my textures.
PostPosted: Wed May 08, 2013 8:41 am  (#7)
Several different Inkscape filters (exported the result for each filter output and blended with GIMP) Odin. The one that has the most impact though is Filters>Textures>Tinted Rainbow. The other presets (and never seems to be the same ones; lol) are for the glossy step. Again, the only reason you can create the marbles is the voronoi stippler. :)
PostPosted: Wed May 08, 2013 10:54 am  (#8)
lylejk: thank you very much, i grabbed it at once!
