It is currently Tue Nov 17, 2026 5:27 pm
 Post subject: Re: Gimp Splash test
PostPosted: Tue Aug 20, 2013 1:29 pm  (#1)
conbagui wrote:
I'm trying create fake 3D look.
I still got a lot to go for a result that would please me.
Well I guest I keep on working on it.
:wow It's sure super colorful!
PostPosted: Tue Aug 20, 2013 1:35 pm  (#2)
It's a good concept. Perhaps if you had some shadowing from the foreground layers onto the layers just behind, you would get a bit more depth from the image.
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
PostPosted: Tue Aug 20, 2013 1:42 pm  (#3)
conbagui wrote:
I'm trying create fake 3D look. I still got a lot to go for a result that would please me. Well I guest I keep on working on it :keybdtype
I like the colors as well, conbaqui!
Just keep in mind what you have in the background of the startup message area. The startup text is normally black but a theme may change that.
PostPosted: Tue Aug 20, 2013 2:11 pm  (#4)
Good design and nice colours. Personally, I would like the text to stand out a little more.
PostPosted: Tue Aug 20, 2013 3:10 pm  (#5)
I agree with Erisian, I think the text is kinda hidden. You can see it but...not too well.
Very pretty and colorful, nice work! :D
PostPosted: Tue Aug 20, 2013 3:53 pm  (#6)
Looking good, from my point of view I have had no trouble reading the text.
PostPosted: Tue Aug 20, 2013 4:30 pm  (#7)
That's improved it nicely. :)
PostPosted: Tue Aug 20, 2013 5:40 pm  (#8)
I too like the bright colours you have used. It is looking great. :bigthup
PostPosted: Tue Aug 20, 2013 7:16 pm  (#9)
:jumpclap :clap :jumpclap :clap
Very cool! Beautiful look!
Liked the colors
bbbbbbbbbbbImage
PostPosted: Tue Aug 20, 2013 7:41 pm  (#10)
Here is an example of the technique I was talking about with shadowing on multiple layers. Not sure if the same kind of thing would help your splash image pop, but it might.
PostPosted: Tue Aug 20, 2013 7:49 pm  (#11)
Wow, that one sure pops, what is that font, I really like it.
PostPosted: Tue Aug 20, 2013 8:09 pm  (#12)
The font is TX Jello. :)
PostPosted: Tue Aug 20, 2013 8:42 pm  (#13)
Thanks, I looked in DaFont but this one doesn't look the same at all.
http://www.dafont.com/tx-jello.font
PostPosted: Tue Aug 20, 2013 8:52 pm  (#14)
Nice looking splash! :bigthup
Try it in all caps Molly. :)
GIMP
