It is currently Mon Nov 16, 2026 10:32 pm
Post new topic Reply to topic  [ 620 posts ]  Go to page 1, 2, 3, 4, 5 ... 31  Next
 Post subject: Environment Map Sharing Thread (Spherical) Bevel Reflect
PostPosted: Wed Feb 05, 2014 8:08 am  (#1)
I thought I'd create a thread to share Environment Maps. Here are a few spherical maps that work well with the Bevel Reflect Script. Post any Environment maps you'd like to share here.
File comment: Spherical Emap Pack #1
Spherical Environment Maps1.zip [1.61 MiB]
Downloaded 3090 times
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
 Post subject: Re: Environment Map Sharing Thread
PostPosted: Wed Feb 05, 2014 11:05 am  (#2)
Thanks for sharing, GnuTux.
PostPosted: Wed Feb 05, 2014 11:14 am  (#3)
Thanks for Sharing, Here is my contribution
PostPosted: Wed Feb 05, 2014 10:23 pm  (#4)
PostPosted: Thu Feb 06, 2014 7:31 am  (#5)
PostPosted: Thu Feb 06, 2014 12:50 pm  (#6)
Here's some limestone spherical maps...
limestone Spheres By Wallace Package A.zip [4.07 MiB]
Downloaded 1966 times
limestone Spheres By Wallace Package B.zip [4.55 MiB]
Downloaded 1950 times
limestone Spheres By Wallace Package C.zip [3.84 MiB]
Downloaded 1858 times
PostPosted: Thu Feb 06, 2014 1:00 pm  (#7)
Thank you for the bowling balls wallace.
PostPosted: Thu Feb 06, 2014 1:09 pm  (#8)
:hehe You're welcome.
PostPosted: Thu Feb 06, 2014 1:43 pm  (#9)
One from my custom gradient.
PostPosted: Thu Feb 06, 2014 2:29 pm  (#10)
How about a brown one, made for a gradient called "Browns".
PostPosted: Sun Mar 09, 2014 3:46 am  (#11)
Here's another one, Red Satin.
PostPosted: Sun Mar 09, 2014 4:07 am  (#12)
thanks he4rty, nice one.
PostPosted: Sun Mar 09, 2014 8:21 am  (#13)
Thanks for the Emap, He4rty!
Here are several more.
There are 2 chocolates, butterscotch and Gerber steel.
File comment: Chocolates, Butterscotch, Gerber-Steel EMaps
4-More-Environment-Maps.zip [184.67 KiB]
Downloaded 1133 times
PostPosted: Sun Mar 09, 2014 9:43 am  (#14)
Well done! I like your job.
Here my contribution
Thanks to you all! :jumpclap
PostPosted: Sun Mar 09, 2014 10:37 am  (#15)
One more
PostPosted: Sun Mar 09, 2014 11:05 am  (#16)
I have forgotten, do environment maps have to be the same layer size as what you are working on? And therefore, I am not so sure how to use round ones as opposed to the straight side ones?
PostPosted: Sun Mar 09, 2014 11:20 am  (#17)
Sorry 2-ton, I had mine made long time ago and I don't remember now how I made it. I think I made it using other way, I'll try to remember how I made it. I don't know how to do sphere with Environment Map neither (my Spanish Gimp is very weird). I don't find the things or I don't have them. I suppose.
PostPosted: Sun Mar 09, 2014 11:25 am  (#18)
2-ton, spherical environment maps ,like these, are meant to be used with the ML Bevel Reflect plug-in and/or the Bevel Reflect Logo script. In general, spherical maps that include transparent sections don't seem to work very well. Neither do maps that contain certain images. I've found that spheres in the range of 250px to 350px seem to work well, but I suppose it's possible that larger or smaller spheres might also produce some interesting results.
Flat environment maps are normally used with GIMP's lighting filter or with the EnviroLogo script, (which uses the lighting filter). I must admit that I've never tried spherical (or circular) environment maps with GIMP's lighting filter, but it might be an interesting experiment. When used with the lighting effects filter, the size of the environment map can have a dramatic effect on the result, especially when using a gradient, pattern or an image as a map. Through experimenting, I've found that flat emaps consisting of patterns, gradients and images should be at least twice the size of the target image, and it some cases, even larger. Remember that environment maps used with GIMP's lighting effects filter (or the EnviroLogo Script) cannot contain an Alpha channel. If they do, they simply won't work.
PostPosted: Sun Mar 09, 2014 2:16 pm  (#19)
THanks for the refresher course. I have not tried out the bevel reflect on a mac as yet. Might be something I should get around to soon. So many scripts, so little time!
PostPosted: Sun Mar 09, 2014 9:00 pm  (#20)
Here's 17 maps I made. Haven't used all of them, so can't tell you how good, or bad they are.
Warrior Maps.7z [1.75 MiB]
Downloaded 1115 times
