It is currently Tue Nov 17, 2026 9:25 am
 Post subject: contour curves wanted
PostPosted: Wed Feb 05, 2014 8:55 am  (#1)
I have all the contour curves in a folder but they are all the same. I would appreciate if some one has the set they would post them..
Mine all just have the diagonal line with no curves in them.
 Post subject: Re: contour curves wanted
PostPosted: Wed Feb 05, 2014 9:37 am  (#2)
Thank you very much.
PostPosted: Wed Feb 05, 2014 10:19 am  (#3)
Don't know if you have these or not Molly but worth the download
100 Curves
PostPosted: Wed Feb 05, 2014 10:29 am  (#4)
yes thanks he4rty, I do have them, they are not all installed in gimp curves yet but I am working on it.
PostPosted: Wed Feb 05, 2014 11:02 am  (#5)
molly: this might be a stupid question, but have you tried those contour curves with the channel set to alpha?
PostPosted: Wed Feb 05, 2014 11:13 am  (#6)
Yes I did AnMal but when I click ok it goes back to the value setting.
PostPosted: Wed Feb 05, 2014 11:36 am  (#7)
molly that's weird! hope it works with the ones from conbagui.
PostPosted: Wed Feb 05, 2014 2:00 pm  (#8)
Whenever I get time I will try them all with some text. Mine might have been okay but anyway, I uninstalled them and replaced them with the ones conbagui sent, They are still not all working the way I think they should but I need to have a better layer that what I was using. I will do them later.
EDIT:
Just tried them on text and they work fine, thanks AnMal
PostPosted: Wed Feb 05, 2014 2:47 pm  (#9)
Thanks, are those different that what you posted before? They seem to be working fine now that I used text and applied each curve to text. They don't work when I click alpha though, they go right back to value
