It is currently Tue Nov 17, 2026 3:13 am
 Post subject: Solid Colour Environment Maps
PostPosted: Sat Feb 08, 2014 12:32 am  (#1)
Wasn't sure whether I should post this in this thread or not, So Tux if you would like to move it over then feel free.
I have been playing around with creating Maps and noticed that there wasn't any solid colour options, I tried with the environment map generator but the results kept coming out very light, So I tried a rehash of my glossy ball idea and have managed to achieve some pleasing results.
1. Download the attached XCF file and open with Gimp
2. Select your chosen colour and fill the layer named "Colour" should be locked so it will only fill the circle.
3. Then export your result as a png or jpg file.
4. run the Bevel Reflect Logo Script and select your newly saved file as the map.
More info on the Script can be found here
Here are just some of my results, as you can see white and black both work equally as good.
Enjoy
Hearty
Solid Colour Maps 01 Updated.xcf [781.91 KiB]
Downloaded 357 times
Solid Colour Maps 01.xcf [681.67 KiB]
Downloaded 306 times
 Post subject: Re: Solid Colour Environment Maps
PostPosted: Sat Feb 08, 2014 12:41 am  (#2)
I think this is a great idea & technique for solid color maps. The results look great. :yes
I think it would fit fine with the other sharing thread, but it might be better to just leave this as a stand alone thread, and post a link to it from the sharing thread. Whatever you think is best, though.
Nice job, He4rty. :bigthup
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
PostPosted: Sat Feb 08, 2014 12:50 am  (#3)
There are about 9 or 10 solid color maps in this thread OP (K1 maps and Blender generated matcaps).
PostPosted: Sat Feb 08, 2014 3:14 am  (#4)
Nice idea and thanks for the maps.
PostPosted: Thu Aug 21, 2014 10:59 pm  (#5)
Updated the first post to included a newer version of the map xcf, its basically the same as before except I have added a mask to the top layer to remove some unwanted artefacts.
PostPosted: Fri Aug 22, 2014 2:51 am  (#6)
Thank you He4rty for sharing your job. It'll be useful for me. :tyspin
PostPosted: Fri Aug 22, 2014 9:54 am  (#7)
Thanks for the update, he4rty. These solid color maps produce a smooth result with no unwanted artifacts. I can just rotate for light direction. :bigthup
PostPosted: Fri Aug 22, 2014 11:09 am  (#8)
@he4rty - I filled the color layer with a pattern!
Thank you for the xcf file
PostPosted: Fri Aug 22, 2014 8:54 pm  (#9)
Thanks everyone for the comments.
Marcello - That is a really nice map and really good results.
