It is currently Thu Nov 19, 2026 3:18 am
 Post subject: Anchor code help
PostPosted: Tue Dec 02, 2014 3:07 pm  (#1)
So basically I want to use anchors in my tutorials that have multiple way of doing it. But for some reason the goto code just doesn't work. Is this because it is removed or am I just using it wrong?
[anchor=top]top[/anchor]
text
text
text
[goto=top]top[/goto]
 Post subject: Re: Anchor code help
PostPosted: Tue Dec 02, 2014 4:14 pm  (#2)
The "Anchor" BBcode is currently not supported. When I get a chance, I'll take a look and see what I can do to implement the code, without it posing any security risks.
PostPosted: Tue Dec 02, 2014 4:43 pm  (#3)
You could always chop your tutorials in individual posts, then you can link to each post, and even create an index:
The downside to this method is that links open in new windows/tabs :(
Kevin
And when you've made a post, you can get it's link and edit the post to include a link to itself
PostPosted: Tue Dec 02, 2014 4:54 pm  (#4)
But then the limit on the number of pictures per post is no longer a worry :)
PostPosted: Tue Dec 02, 2014 5:43 pm  (#5)
There is no limit to the number of images that can be embedded in a post. Limits only apply to the number of attachments in a post, which can be avoided by using the image uploader Image.
PostPosted: Wed Dec 03, 2014 1:44 am  (#6)
The anchor code is working, its just the goto code, when make an anchor called  test  and I add #test to the end of the url (make sure there is not already something like that in the url!) then it jumps to the anchor.
(Just to make sure that the anchors are still not working you can try clicking [goto=test]here[/goto]. If the anchor code is indeed fixed it will take you to the underlined test text)
PostPosted: Sun Feb 08, 2015 12:56 pm  (#7)
Did the goto/anchor code get fixed already?
