It is currently Sun Nov 22, 2026 11:32 pm
 Post subject: Need Help With GimpScripts.com
PostPosted: Sun Feb 07, 2016 10:36 am  (#1)
I am having a problem with the sister site. Any one have a clue who I should be addressing this with?
(Solve if you can ... ;) )
 Post subject: Re: Need Help With GimpScripts.com
PostPosted: Sun Feb 07, 2016 1:06 pm  (#2)
Yes i still have Mod access so what is the issue?
PostPosted: Sun Feb 07, 2016 9:18 pm  (#3)
2 Days ago I uploaded the scripts from this thread, first post.
This was my first attempt at uploading to gimpscripts ever.
I forgot to add two pieces of info:
1. They require G'MIC 1.6.8 or greater
2. They optionally require DIEGO_color_mod_lcs
They appear to not have uploaded as I cannot find them. I seem to recall reading that a "first upload" requires manual intervention by someone.
Also, since I do not know what I can and cannot do there regarding editing, could the main content be edited (I will do it myself if I have the permissions) to include that info? If not editable (by self or others) I can add it as a first comment to the post.
PostPosted: Mon Feb 08, 2016 3:47 am  (#4)
...so, it's not only me who doesn't master that ancillary site; why not to improve it so that posting/amending/updating is made easy as posting/amending/updating under gimp-chat?
(or: why not to reserve a specific thread under Gimp-chat ONLY for that purpose? the current one is a pot-pourri)
PostPosted: Mon Feb 08, 2016 3:48 am  (#5)
Second dinasset's motion!
PostPosted: Mon Feb 08, 2016 1:54 pm  (#6)
Normally if you contact Tux he will give you access to upload and edit your scripts. I thought this was already possible via the upload scripts and plug-ins link? Seems Tux may have the uploads set to be checked by a mod as to whether they be a safe file or not. Then a mod posts the files.
Why dont you send them to me via email and i will upload them to gimpscripts for you guys. PM me for my email contact. I will set up a sticky forum under scripts and plug-ins with this information.
Can you guys upload via that link though? ie http://gimpscripts.com/upload-script/
