It is currently Mon Nov 23, 2026 1:01 pm
 Post subject: Demonstrating GimpChat access
PostPosted: Fri Jan 27, 2017 7:04 pm  (#1)
Just use the right address, in your hosts file....
 Post subject: Re: Demonstrating GimpChat access
PostPosted: Fri Jan 27, 2017 10:50 pm  (#2)
i feel lonely loggin in to this site using hosts file.
PostPosted: Sat Jan 28, 2017 5:36 am  (#3)
I am sure you won't be lonely for long. Others will be logging in as every minute passes!
david.
PostPosted: Sat Jan 28, 2017 5:46 am  (#4)
just logged in (accessed using the address provided by david, thanks)
PostPosted: Sat Jan 28, 2017 5:52 am  (#5)
...but "view active topics" only shows only those entered after the "resurrection"
(the "view unanswered posts" works...)
PostPosted: Sat Jan 28, 2017 12:54 pm  (#6)
That's because "View active topics" defaults as last 7 days you can change that at bottom to show over different periods.
PostPosted: Sat Jan 28, 2017 12:55 pm  (#7)
david.
Alright it's not lonely anymore but guests who try to follow links to GC will still be broken :(
PostPosted: Sat Jan 28, 2017 1:38 pm  (#8)
No Tin, at the first tries I changed to "all", "1 year", "6 months" always getting only the ones posted just recently.
After a while it started to work properly. Time to "reload" data? IDK
PostPosted: Sun Jan 29, 2017 3:21 am  (#9)
I am back on GimpChat.
Late 2017 iMac Retina 4K 21,5 inch Mac OS High Sierra version 10.13.4
3,6 GHz Intel Core i7
16 GB Ram 2400 MHz DDR4
Graphic card Radeon Pro 560 4096 MB
Affinity Photo and Affinity Designers.
PostPosted: Sun Jan 29, 2017 3:35 am  (#10)
nice to have you back
one at a time we will reconstitute a group of active members
PostPosted: Sun Jan 29, 2017 4:00 am  (#11)
GimpChat Owner
I am deeply sorry for what happened for the past time, it is all my fault...
-Omega
PostPosted: Sun Jan 29, 2017 4:46 am  (#12)
Once bitten, twice shy.
PostPosted: Sun Jan 29, 2017 9:43 am  (#13)
Omega, you got us back, so thank you for your perseverance. Perhaps there is a way to have the global mods be able to do more to take some of the work load off of your shoulders.
PostPosted: Mon Jan 30, 2017 7:06 am  (#14)
-Omega
Were back up, and all content is safe, so that's all that matters Omega. :) Thank you.
PostPosted: Mon Jan 30, 2017 9:55 am  (#15)
-Omega
