It is currently Mon Nov 23, 2026 2:39 pm
 Post subject: My Gimp doesn't stay logged in
PostPosted: Tue May 09, 2017 12:27 pm  (#1)
I don't know what is going on with my gimpchat, it is either my computer OR problems with the site.
Every time I log in, it doesn't stay logged in when I go out of GC. I do have the box checked to keep me logged in.
Anyone else having this problem?
Thanks in advance.
 Post subject: Re: My Gimp doesn't stay logged in
PostPosted: Tue May 09, 2017 12:50 pm  (#2)
Thanks in advance.
There have been a lot of people experiencing this.
As for myself,
I have not had this issue.
It could also have something to do with the server,
but I can't say for sure if this is the cause.
This could also be a web browser issue and this is also a guess,
as to what might be causing this issue.
Have you checked if there are any updated for the web browser you're currently using?
PostPosted: Tue May 09, 2017 2:22 pm  (#3)
AFAIK you need to make sure that your browser keeps the cookies for GC permanently so that they survive a browser restart.
PostPosted: Tue May 09, 2017 2:45 pm  (#4)
thanks ofnuts but gc is the only place it happens.
PostPosted: Tue May 09, 2017 3:21 pm  (#5)
Still worth checking what your browser does with the GC cookies.
PostPosted: Tue May 09, 2017 4:11 pm  (#6)
I went into properties .. advanced and I have accept cookies from sites and accept third party cookies version 52.0.2
PostPosted: Tue May 09, 2017 8:16 pm  (#7)
The important part in the "Keep until" setting just below these two.
PostPosted: Wed May 10, 2017 7:16 am  (#8)
@ofnuts, should I check keep until they expire, or keep until I close, those are the only two choices.
PostPosted: Wed May 10, 2017 10:15 am  (#9)
@molly,
If you are using Firefox, it is something they have changed with an update.
When you click in the username box, the message pops up.
At the bottom of the box I assume it says molly (mine says david), if you click on the name it should enter the username and login.
I tried to add a screenshot, but....
david.
PostPosted: Wed May 10, 2017 10:27 am  (#10)
I will try that David Thanks
I did that David and it worked, it is just an extra step, thats all. I wish they would leave things alone. It was fine before they messed with it... :hoh :gaah :roll:
PostPosted: Wed May 10, 2017 11:57 am  (#11)
Online
Happens to me often enough too, Molly. Not sure what's causing this, but my browser just re-logs me in after I click log-in. Still, it's pretty irritating. :)
PostPosted: Wed May 10, 2017 12:46 pm  (#12)
yes you are right Lyle it is irritating.
PostPosted: Wed May 10, 2017 2:57 pm  (#13)
The best thing to do is to select "Keep until you close Firefox" (this applies to all cookies), and then use the "Exceptions..." button to keep permanently ("Allow" status) those of a few select sites (the few sites you trust, such as GimpChat).
PostPosted: Wed May 10, 2017 3:41 pm  (#14)
To disable the Firefox logon warning message see: http://www.trishtech.com/2017/03/disabl ... n-firefox/
I have changed mine back to its original mode - I wish they wouldn't make these "improvements"!!!
david.
PostPosted: Thu May 11, 2017 6:24 am  (#15)
A wise person once said
"with progress comes chaos" =)
For instance.
Any time you update GIMP or G'MIC it seems filters get broken. Seems to be the case with most anything.
PostPosted: Thu May 11, 2017 9:22 am  (#16)
david.
Thanks David, I just did those quite clear instructions you sent.
PostPosted: Thu May 11, 2017 9:29 am  (#17)
How do I grant a site special permissions?
PostPosted: Thu May 11, 2017 9:38 am  (#18)
Check this out and see if it helps.
How to Modify Permissions for Individual Websites in All Browsers
PostPosted: Thu May 11, 2017 1:31 pm  (#19)
Come to Gimp Chat and try this.
(See image "Untitled_1.png" below).
Right-click in the same place I did in the image below.
(The little red star, is where I right-clicked)
The dialog should open.
Select "View Page Info".
The next dialog should then open (see image "Untitled_2.png" below).
Where you can check Gimp Chat's permissions.
They should look like what I have checked.
This is how it's done in FF.
Let me know if this works for you.
