@Barry
After the download, I discovered that the tool selection area (and related text/fonts/tools) are SO small that they are not usable to me....snip....I suspect it's a screen resolution issue BUT I want to keep this resolution
This is a Gimp theme issue with high definition displays. You can get improvements with the link that Ofnuts posted.
Screen resolution is another thing again. Gimp 2.10 (unlike Gimp 2.8) is good at determining the screen pixel density automatically. This laptop I am using is 158x158 pixels/inch. You should stick with the correct setting.
Why? For most editing there is a toggle in the View menu
dot-for-dot Default is ON. One screen pixel = one image pixel. If you want to see what your work-of-art looks like printed, set the zoom to 100% and turn dot-for-dot off. For editing keep it on.
This example (zoom = 100%) 400 x 400 pix @ 200 ppi printed would be 2"x 2" about 5 cm x 5 cm.
Seen some horrors where horizontal and vertical resolutions have been 'adjusted'. Typically to stretch something rather than scaling the actual image.
