It is currently Mon Sep 28, 2026 6:39 am
 Post subject: In Chrome I cannot scale sized down image back to full size
PostPosted: Mon May 02, 2011 2:45 pm  (#1)
The title says it all. When an image is sized down you can click on it and get the option to view it in its original size. This option doesn't work for me. Nothing happens when I try.
I'm using google chrome. Does it work in Firefox?
 Post subject: Re: In Chrome I cannot scale sized down image back to full size
PostPosted: Mon May 02, 2011 5:06 pm  (#2)
Works for me in FireFox.
If you are talking about image links in the forum posts that is.
PostPosted: Tue May 03, 2011 10:36 am  (#3)
Work in Chrome for me - 11.0.696.60 (Official Build 83294)
-Rob A>
PostPosted: Tue May 03, 2011 12:47 pm  (#4)
Chrome on XP here. Build 11.0.696.60 and Expand to actual size doesn't do anything. :?
Just tried firefox 4 and it works fine in there.
PostPosted: Tue May 03, 2011 5:52 pm  (#5)
I use Firefox 3.6.17 and it works fine.
PostPosted: Tue May 03, 2011 6:10 pm  (#6)
I tried it on a window 7 32 bit machine with Chrome and it didn't work there either....
PostPosted: Wed May 04, 2011 9:43 pm  (#7)
The image has to be larger than your page size for that option...
try this one:
viewtopic.php?f=11&t=1581#p19675
I click once and it opens in lightbox and enlarges to the screen size. I click the expand to full size button and it enlarges again.
Attached are screen grabs.
-Rob A>
PostPosted: Wed Aug 10, 2011 9:43 pm  (#8)
Thread necromancy -
Now in chrome I don't get any lightbox at all. The little tools appear (prev, next, full size, close) in the lightbox frame, but no image :(
-Rob A>
PostPosted: Thu Aug 11, 2011 1:40 am  (#9)
Works for me in Chrome....
PostPosted: Thu Aug 11, 2011 5:15 am  (#10)
I'm currently using older version of Highslide JS for image pop-ups. A quick test of the latest Highslide JS release didn't work as I expected but it looks like a lot has changed in the new release. I'll take a closer look at the new version and try to troubleshoot the problems.
I don't use chrome and I really don't want any googleware installed on my computer. Can someone who is using Chrome go here and test to see if the latest version of Highslide JS is working properly with Chrome? No need to make any changes here unless I'm actually fixing something. :)
Thanks!
PostPosted: Thu Aug 11, 2011 5:31 am  (#11)
Thanks!
Seems to work on Linux Chrome.
You can have Chrome on your machine for test purposes without selling your soul to Google :)
PostPosted: Thu Aug 11, 2011 1:33 pm  (#12)
Didn't you say that the Highslide version I'm currently using here on Gimp Chat works OK for you, ofnuts?
Can someone who is having an issue with highslide here check the link I posted to see if the latest version works any better?
I like Highslide but if it's going to be a problem for some members, I don't have to implement it here.
PostPosted: Thu Aug 11, 2011 2:23 pm  (#13)
My regular brower is Firefox but I also have Chrome, si I fired it up and went to http://highslide.com/configurator.php to try the stuff, and it works as advertized.
PostPosted: Thu Aug 11, 2011 2:32 pm  (#14)
Yes, but does the version of Highslide I'm currently using here work for you when using chrome?
PostPosted: Thu Aug 11, 2011 4:13 pm  (#15)
Yes, it's also OK
PostPosted: Thu Aug 11, 2011 4:34 pm  (#16)
Thanks for checking! Maybe someone who is having problems here can check the latest version to see if the problem has been fixed.
Seems odd that it works for some and not for others.
PostPosted: Thu Aug 11, 2011 6:02 pm  (#17)
When I inspect the element I get:
<img class="highslide-image" style="max-width: 9999px; z-index: 3; position: relative; visibility: visible; top: 0px; left: 0px; width: 0px; height: 0px; cursor: url(http://www.gimpchat.com/styles/abbcode/highslide/zoomout.cur), pointer; display: block; " title="Click to close image, click and drag to move. Use arrow keys for next and previous." src="http://www.gimpchat.com/download/file.php?id=2149">
The width and height are set to 0 :(
Samples on the highslide site all work fine for me, it is just here it doesn't work.
-Rob A>
PostPosted: Thu Aug 11, 2011 9:10 pm  (#18)
works ok in Opera
PostPosted: Fri Aug 12, 2011 12:57 am  (#19)
Well, if you are not seeing any image, I'd expect to see width and height at 0. I say that is an effect, rather than the cause.
I went ahead and installed Google Chrome on my laptop for testing (even though I vehemently disagree with their TOS). I'm using the latest version: Chrome 13.0.782.112 (32bit) under Fedora 14.
After testing, it appears the version of Highslide I am using here on Gimp Chat is working fine in Chrome.
Inspecting the element..
As you can see, all is well. Considering that it's working for both me and ofnuts in Chrome and the HTML Gimp Chat is generating seems to be in working order, I'm at a loss as to why it's not working for you.
Are you running adblock or other Chrome addons? You could try disabling those just for a test. I understand there are conflicts with some Chrome addons.
What OS & Chrome versions are you using?
