It is currently Thu Nov 19, 2026 1:40 am
 Post subject: alignment tool
PostPosted: Sun Jan 06, 2019 6:50 am  (#1)
I have never managed to make this tool work.
Basic example: a purple layer in the background and a green layer above smaller and not centered. To center it, I select the alignment tool, I check that my layer is active and the buttons of the tool are inoperative.
Image Image
I tried with these 2 options:
Image Image
So I have to use the guides or the grid ...
 Post subject: Re: alignment tool
PostPosted: Sun Jan 06, 2019 6:58 am  (#2)
Hi Level_0,
Try before, Layer - Crop to content, click on the object and then apply the alignment tools.
PostPosted: Sun Jan 06, 2019 7:35 am  (#3)
Krikor wrote:
Hi Level_0,
Hi Krikor
PostPosted: Sun Jan 06, 2019 7:46 am  (#4)
level_0 wrote:
Krikor wrote:
Hi Level_0,
Hi Krikor
"impossible de rogner car le calque actif est dejá rogné just'a son contenu"
Ok, then just click on the object (circle's layer) and then apply the alignment tools.
Relative to Image or Relative to first item
PostPosted: Sun Jan 06, 2019 8:01 am  (#5)
PostPosted: Sun Jan 06, 2019 8:11 am  (#6)
That's exactly it, :clap thank you Krikor
it makes appear a small square to the 4 vertices of the dashed square ...
and yet I searched the internet several times without ever finding this indication.
PostPosted: Sun Jan 06, 2019 4:35 pm  (#7)
Y'a pas à chercher... faut juste lire la doc:
https://docs.gimp.org/fr/gimp-tool-align.html
PostPosted: Sun Jan 06, 2019 4:50 pm  (#8)
EDIT:
ofnuts replied in French ... (so I did the same) :)
Before asking a question on any forum, graphic or computer, I always take the time to search, so if I come to ask for help, it's because I did not find or not understand . ;)
PostPosted: Sun Jan 06, 2019 5:21 pm  (#9)
et la comprendre....mais 77 ans dans un mois donc je pense qu'Alzheimer est arrivé!
bonne soirée ofnuts
Krikor wrote:
level_0 wrote:
Krikor wrote:
Hi Level_0,
Hi Krikor
You guys need to communicate using English within your postings.
If you do this again.
I will have to delete the post(s).
Thanks.
