It is currently Mon Nov 09, 2026 7:41 am
 Post subject: GimpChat errors.
PostPosted: Fri Nov 22, 2024 5:22 am  (#1)
@ Wallace
Please fix or report to the administrator;
viewtopic.php?f=9&t=21349&p=293243#p293216
This is not a theory, but experimentally confirmed errors.
Other examples:
A bizarre number of downloads and two identical files (facilitates DDS attack):
viewtopic.php?f=9&t=21424
The number of downloads (467)is greater than the number of views (390);
viewtopic.php?f=9&t=21431
 Post subject: Re: GimpChat errors.
PostPosted: Fri Nov 22, 2024 3:01 pm  (#2)
MareroQ wrote:
@ Wallace
Other examples:
Thank you MareroQ.
I did notice the download numbers.
I'll need to contact Omega about this issue.
Thanks again.
PostPosted: Fri Nov 22, 2024 3:06 pm  (#3)
ah those attacks, I have almost half a million hits on my site and i am sure they're from bots, they even change IPs too if you block them so there's no way to prevent them just hope they're done with the site and move on.
PostPosted: Fri Nov 22, 2024 3:10 pm  (#4)
trandoductin wrote:
ah those attacks,
There is nothing I can do about this.
I've contacted Omega in regard to this issue.
PostPosted: Fri Nov 22, 2024 6:31 pm  (#5)
I doubt there's much Omega can do except block ips that hits lots but they just change their ip anyways.
PostPosted: Sat Nov 23, 2024 12:05 am  (#6)
@ Wallace.
Thank You very much for your intervention.
PostPosted: Sat Nov 23, 2024 12:07 am  (#7)
MareroQ wrote:
@ Wallace.
