It is currently Wed Nov 18, 2026 8:49 pm
 Post subject: GIMP-Chat PM issue
PostPosted: Sun Dec 11, 2011 1:05 pm  (#1)
GIMP Version: Irrelevant
Operating System: Linux
OS Version: Debian
GIMP Experience: Advanced Level
I have a strange issue with GIMPchat's PM system. Quite simply, I don't get a "Send" button. I would have asked the staff over PM, but well ... that is sort of the issue. ;)
Clearly I've sent PM:s before, and never had any issues (I don't remember exactly where the send button used to be, but I never noticed it as an issue). If I (in the case of a reply) click "reply" or "quote" button in a received PM, I get the input form just fine, everything works, except there is no way to send the result off. I have made sure to clean out my input/send folders in case that was the issue, but to no avail.
It seems to be the case both for new PMs as well as replies/quotes. I use latest Firefox under Linux, but it has worked before today, which is why I thought I'd ask if this is something in the forum software (i.e. if others also see this).
Griatch
 Post subject: Re: GIMP-Chat PM issue
PostPosted: Sun Dec 11, 2011 1:11 pm  (#2)
I can confirm the lack of a send button using Firefox 6.02 on Windows XP
PostPosted: Sun Dec 11, 2011 1:13 pm  (#3)
I dont see it using latest google chrome...
PostPosted: Sun Dec 11, 2011 1:49 pm  (#4)
No send button either with FF 3.6 on Ubuntu 10.04 (a cursory look at the page source code seems to indicate that the HTML for the button isn't generated...)
PostPosted: Sun Dec 11, 2011 1:55 pm  (#5)
I'm having the same problem. Using Firefox.
PostPosted: Sun Dec 11, 2011 2:08 pm  (#6)
Perhaps the PM system has been disable temporarily. Just a thought, maybe.
PostPosted: Sun Dec 11, 2011 3:19 pm  (#7)
Thanks for bringing this to my attention!!
It should be fixed now. It must have been a side effect of some of the optimization I'm working on.
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
