It is currently Tue Nov 17, 2026 8:26 pm
 Post subject: What Theme Is This
PostPosted: Sat Mar 10, 2012 6:59 pm  (#1)
site
i have been wondering
and how do the recent post show up above the index
 Post subject: Re: What Theme Is This
PostPosted: Sat Mar 10, 2012 7:08 pm  (#2)
GIMP Chat uses a customized theme based on the default theme subsilver2 of phpBB3.
http://www.phpbb.com/
http://www.phpbb.com/community/viewtopi ... 0&t=573680
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
PostPosted: Sat Mar 10, 2012 7:13 pm  (#3)
okay thank u
PostPosted: Sat Mar 10, 2012 8:19 pm  (#4)
how do i use it
PostPosted: Sun Mar 11, 2012 12:21 am  (#5)
To install the forum-
You have to install it onto your server.The server needs to have PHP installed also.
In most cases you just browse to the install file and enter your MySQL database info.
The new theme would then go in the themes directory.Then browse to your Admin Panel and select the theme.
PostPosted: Sun Mar 11, 2012 1:38 am  (#6)
War Hero wrote:
how do i use it
I'm not sure what you mean my "use it" but Rod is correct when it comes to installing phpBB onto your server.
This is not really the venue in which to discuss phpBB related issues. I would suggest that you post phpBB related questions to the appropriate threads on the phpBB community support forums.
PostPosted: Sun Mar 11, 2012 11:20 am  (#7)
dang, can someone just do it for me?
lol
PostPosted: Sun Mar 11, 2012 11:54 am  (#8)
I am afraid not War Hero. This is a Gimp forum, not a web-site builder site. As Tux said, go into a phpBB forum and get help there.
PostPosted: Sun Mar 11, 2012 11:57 am  (#9)
kk, thank you.
