It is currently Sat Nov 21, 2026 1:58 am
 Post subject: BBCode
PostPosted: Sun Apr 08, 2012 10:06 pm  (#1)
● Gradient doesn't really work and neither does:
[border=red]text[/border] [border=blue,3]text[/border] [border=green,1,dotted]text[/border]
● font color gold, goldenrod,(without being orangy or brown) shows better on the page then the yellows.
● Would be nice to have some BBCode features like these.
COLORSLIDE
http://www.phpbb3bbcodes.com/viewtopic. ... db3c74f105
ROTATING TEXT
RAINBOW TEXT
BBCODE LIST
http://www.phpbb3bbcodes.com/viewforum. ... db3c74f105
text with gradient
 Post subject: Re: BBCode
PostPosted: Sun Apr 08, 2012 10:28 pm  (#2)
This is text with a gradient
This is font selectedwith the color selector.
PostPosted: Sun Apr 08, 2012 10:37 pm  (#3)
● Okay I was not using the gradient tool properly. My fault. I see you have to choose the Pre Selected Colors or the others. It sure freaked me out when it took me to another opened tab.
● I can just type in gold for color myself because it has more of a yellowish look then the brownish one you posted.
Thanks Rod! :)
But it would be nice to have some of the other bbcodes. Just suggesting and hoping for it.
PostPosted: Sun Apr 08, 2012 10:47 pm  (#4)
Tux may be able to add these for you. He is the owner. :)
PostPosted: Sun Apr 08, 2012 11:04 pm  (#5)
You can already do gradient colored text.
Edit:
Oh; see you already figured it out. I tend to not read through threads like I should since I'm lazy. lol
PostPosted: Mon Apr 16, 2012 3:26 am  (#6)
I discovered this BBCode that looks cool and works on here.
If the webpage has a different theme background color then the text will appear white and then black.
The tags are [/fade].
[fade]Gimp is great ![/fade]
Gimp is great !
PostPosted: Mon Apr 16, 2012 8:57 am  (#7)
Gimp is great !
Cool! :)
PostPosted: Mon Apr 16, 2012 10:42 am  (#8)
Greetings,
I went ahead and added in an icon for fade but many other specialty BBcodes, such as glow, drop shadow and such are browser specific so those aren't supported. Gimp Chat uses a custom modification for BBcode so the actual codes may vary from what is listed on the phpBB3 website. Hovering your mouse over the BBcode icon will display a "How-to" in the box below the codes.
We actually have a posting policy in our Rules Section. While it is not strictly enforced, we do encourage members to avoid flashing text, weird color combos that are hard to read and other special effects, which can be very distracting and really doesn't add anything to a post.
14. Please do NOT post using all capital letters. Using all caps is considered SHOUTING!! Also, please refrain from posting very large or very small text. Please stick with black text on the light background. Using other colors for your post text is very distracting and using light colors like yellow or pink for your message text makes it very difficult to read. Only use color to highlight certain areas of your post.
PostPosted: Mon Apr 16, 2012 8:29 pm  (#9)
Thanks for the Text fadeIn fadeOut button GnuTux ! Image
PostPosted: Thu Oct 11, 2012 11:28 am  (#10)
Hello.
Is it possible to resize an image with BBcode on this forum?
I tried with:
[img=200,80]http://image.jpg[/img]
or
[img=w,200]http://image.jpg[/img]
or
[img=50%]http://image.jpg[/img]
But it does not work.
Thank you.
PostPosted: Thu Oct 11, 2012 1:43 pm  (#11)
Fred Miranda allows this, but not here. The side itself automatically resizes large images and you then can click the image to expand. :)
PostPosted: Thu Oct 11, 2012 2:43 pm  (#12)
It's true.
But sometimes you want the image to be not as large as gimpchat resizes them and not as small as in the thumbnails :)
PostPosted: Thu Oct 11, 2012 4:30 pm  (#13)
If you are using ImageShack (as I do), there is an uber secret resizer but it's clunky (I use it often here). After you upload your image to Imageshack, it will automatically give you an info page for your image. What you do is, for the link part of BBC, you pick the direct image link, but for the image, you right click on the small image and it gives you the small image link (crop). Replace that with medium is what I usually do. Other alternatives are large and landing. Had a list of all the options, but don't know where I copied the list at at this moment. lol
below are some examples (click here for the thread where I posted this response):
http://imageshack.us/scaled/avatar96/89 ... glssvm.jpg
http://imageshack.us/scaled/crop/89/amf7516glssvm.jpg
http://imageshack.us/scaled/small/89/amf7516glssvm.jpg
http://imageshack.us/scaled/medium/89/amf7516glssvm.jpg
http://imageshack.us/scaled/landing/89/ ... glssvm.jpg
http://imageshack.us/scaled/large/89/amf7516glssvm.jpg
PostPosted: Thu Oct 11, 2012 4:31 pm  (#14)
Gimp Chat downwardly resizes images wider than 760px. Image widths less than 760px will not be resized.
PostPosted: Thu Oct 11, 2012 7:47 pm  (#15)
Ok. Thanks.
@lylejk, I'll consider that. Thank you!
PostPosted: Fri Oct 12, 2012 3:12 am  (#16)
Thanks GnuTux, that's a useful number to know as I'd rather be in control of the resizing process than let the forum do it automatically, as I don't like the way it does resizing.
Pity it's not 800px, as now I have to make a GimpChat option on my re-sizing script ;)
Kevin
PostPosted: Fri Oct 12, 2012 1:11 pm  (#17)
Is that for the 768px tablet breakpoint?
PostPosted: Fri Oct 12, 2012 1:47 pm  (#18)
The reason we need to down size images is because sometimes, you want to post large images, but you don't want that image to appear full size and stretch the screen. A long thread of large images that forces you to scroll left and right can be very annoying and doesn't make for a good user experience.
We need to be able to size down large images but I'm not married to the size of 760px. The reason I chose 760px was based on a poll I did several years ago asking about screen resolution. It was determined that quite a few GC members used 1024px screen resolution. When you add in the size of the avatar and other style formatting, 760px was about the largest size I could use without forcing the 1024px screen resolution user to have to scroll left and right when viewing large images.
Maybe it's time to bump that thread and get another feel for what resolution most people are using. 800px might be OK at this point.
On a side note: I use the lightbox script to resize images. It also allows the user to zoom, forward/next and do a slideshow of all the images on the page, which is :coolthup
PostPosted: Fri Oct 12, 2012 2:42 pm  (#19)
Exactly, and that is a very good feature in the forum.
But sometimes you want the image can be seen even a bit smaller than 760px, without losing the ability to enlarge to full size by clicking on the image. And the thumbnails option is also useful, but in other cases they are too small. An average option between 760px and thumbnails size could also be useful. For example if you wanted to compare two images together by putting them one above the other, 760px is still large and you could not see the two images on the same screen for comparison.
In some forums I have seen that when you insert an image is given as an option the possibility to enter the size you want the image to have in the forum, you being able always click on the image to enlarge to full size.
I wondered how hard would be to implement it in GimpChat :)
