It is currently Sat Nov 21, 2026 12:06 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3  Next
 Post subject: My Gimp Chat page has changed---How do I get it back to normal?
PostPosted: Fri Sep 14, 2012 5:58 am  (#1)
I was looking for the board to see the banners and my page turned into something I don't want. When I am in my main page it is the same, not just in Gimp chat. Can someone please help me get back to the default profile? thanks
:oops: :roll:
 Post subject: Re: My Gimp Chat page has changed---How do I get it back to normal?
PostPosted: Fri Sep 14, 2012 6:46 am  (#2)
I was going to be helpful here (It looks like you've set to use a mobile style for the board) . I looked through the banner challenge thread to find where GnuTux said how to change the board style: viewtopic.php?f=13&t=4742&start=100#p63173
BUT the option to select the board style is NOT THERE :( So I think you need GnuTux to fix it (I suspect it's got broken by the changes to incorporate the rotating banner)
Kevin
PostPosted: Fri Sep 14, 2012 6:57 am  (#3)
Thank you Kevin, It is also messed up in my home page so it has nothing to do with Gimp Chat. I have no idea how to change it back to the default look.
PostPosted: Fri Sep 14, 2012 7:00 am  (#4)
I don't run your browser, but your looking for a setting to do with 'page styles'.
PostPosted: Fri Sep 14, 2012 7:01 am  (#5)
First thing I would check is the view style, although you should have seen the forum banner.
PostPosted: Fri Sep 14, 2012 7:06 am  (#6)
I have tried both basic style and no style, remains the same
PostPosted: Fri Sep 14, 2012 7:14 am  (#7)
Reinstall Firefox.
PostPosted: Fri Sep 14, 2012 7:18 am  (#8)
Thanks Mike, might have to do that. I am using Fedora so I will look into it.
PostPosted: Fri Sep 14, 2012 7:21 am  (#9)
I see you have a toolbar on Firefox that I don't recognize, but it does appear to have a "Clear Cache" button - have you tried that?
PostPosted: Fri Sep 14, 2012 7:22 am  (#10)
before you reinstall, you might have enabled ad-block
Look in tools -> add-ons and if ad-block is there disable it and see if that makes a difference.
PostPosted: Fri Sep 14, 2012 7:24 am  (#11)
Tried that and it is still the same.
PostPosted: Fri Sep 14, 2012 7:31 am  (#12)
The banner image I can make disappear by turning javascript off, but the rest of the formatting is still there. - puzzled
PostPosted: Fri Sep 14, 2012 7:54 am  (#13)
I came over to Windows and everything is fine here but I expected it to be because this is a separate hard drive. So whatever I did in my Fedora FF has got me completely baffled too Kevin.
PostPosted: Fri Sep 14, 2012 9:10 am  (#14)
I have had exactly the same problem with Google mail for a long time. Good job I don't use it anymore.
PostPosted: Fri Sep 14, 2012 9:12 am  (#15)
problem is that I don't use google mail. It has to be something simple, but it is just the hard task is at finding it.
PostPosted: Fri Sep 14, 2012 9:31 am  (#16)
Another thing that is missing is under my board preferences, "My board style is not there. It was there up until yesterday. How can that disappear too? :hoh
PostPosted: Fri Sep 14, 2012 9:44 am  (#17)
I refer you back to post number 2 in this very thread: viewtopic.php?f=13&t=5255#p65856 ;)
Kevin
PostPosted: Fri Sep 14, 2012 9:59 am  (#18)
Oops sorry Kev. I did see that. So it is just not mine then, that is a positive, lol
PostPosted: Fri Sep 14, 2012 10:16 am  (#19)
Is it like that on any webpage or just this one, I use firefox and sometimes it has happened to me, mosst recently with facebook.
I just cleared all the browsing history, by going tools>clear history, closed firefox and reopened and it was fine.
PostPosted: Fri Sep 14, 2012 10:27 am  (#20)
Thanks he4rty, but tried that and it didn't work. I even rebooted my pc.
