It is currently Mon Sep 28, 2026 10:27 am
 Post subject: Linking Directly To A Specific Post In A Thread
PostPosted: Thu Dec 09, 2010 11:47 pm  (#1)
I've added a post number in the upper right corner of each post in a thread. The post number links directly to that post, making it easy to link directly to a specific post in a thread.
Example:
viewtopic.php?f=11&t=317#p4875
 Post subject: Re: Linking Directly To A Specific Post In A Thread
PostPosted: Fri Dec 10, 2010 12:09 am  (#2)
Very nice addition Tux, thanks! =)
PostPosted: Fri Dec 10, 2010 12:19 am  (#3)
Example:
Nice! :geek
I always just used the icon next to the word Posted above the post entry box.
I did that on the same page you did with your link. My link is little different but gets you to the same post.
http://gimpchat.com/viewtopic.php?p=4875#p4875
PostPosted: Fri Dec 10, 2010 12:36 am  (#4)
Yep, that's another good option to achieve the same thing, it's just not as obvious. Kinda like the view last post in thread link..
PostPosted: Fri Dec 10, 2010 12:42 am  (#5)
Yes. Your mouse aim has to be good for those puny icons. :hehe
