It is currently Mon Oct 26, 2026 11:37 pm
 Post subject: Can Someone Do Me a Favor?
PostPosted: Sat Jul 19, 2014 2:04 pm  (#1)
I need some path gradient definitions from an EPS. I can get to the particular paths using Inkscape, but the gradients are all wrong.
I tried online converting .eps to .svg, and the gradients were still wrong.
So in desperation, I ask if anyone with photoshop would be willing to convert this file for me. DM to let me know, please. I have all the necessary permission to use the file, but I can't redistribute. So I'm embedding a .png copy of the file so you can see what it looks like, but I'd rather send the actual file only to someone who can help.
Thanks!
 Post subject: Re: Can Someone Do Me a Favor?
PostPosted: Sat Jul 19, 2014 6:22 pm  (#2)
What do you need exactly? Gradient definition or EPS conversion (to what file format)?
I can create CSS or XTML docs out of your EPS file, you can open them in any text editor and look up the gradient definitions
they look like
var gradient;
      // layer1/Path
      ctx.save();      ctx.beginPath();      ctx.moveTo(230.0, 204.0);      ctx.lineTo(0.0, 204.0);      ctx.lineTo(0.0, 0.0);      ctx.lineTo(230.0, 0.0);
      ctx.lineTo(230.0, 204.0);      ctx.closePath();
      gradient = ctx.createLinearGradient(0.0, 102.0, 230.0, 102.0);
      gradient.addColorStop(0.01, "rgb(182, 159, 148)");
      gradient.addColorStop(0.43, "rgb(210, 193, 174)");
      gradient.addColorStop(0.71, "rgb(171, 150, 138)");
      gradient.addColorStop(0.90, "rgb(220, 209, 196)");
      ctx.fillStyle = gradient;
      ctx.fill();
      ctx.restore();
Can convert to SVG, PDF, PSD, TIFF (and any bitmap, of course)
Is that what you're after?
BTW, Illustrator is what you need for this, not PS.
PM me if this is of any help.
PostPosted: Sat Jul 19, 2014 7:03 pm  (#3)
Yeah! Illustrator!
Anyway, I'll DM you.
