It is currently Wed Oct 28, 2026 7:24 am
 Post subject: Black and White clipart wont colour.
PostPosted: Mon Sep 08, 2014 4:14 am  (#1)
I know I have seen an answer to this somewhere but forgot the answer.
I have found a PD clip-art image that I would like to use for something. I cannot colour it or do anything else, it keeps going grey. I have been able to make it Black and white by using threshhold. It is a sRGB picture with a RGB working space.
Do I need to do any thing to it before I can change it?
 Post subject: Re: Black and White clipart wont colour.
PostPosted: Mon Sep 08, 2014 4:17 am  (#2)
Image>Mode>RGB :)
PostPosted: Mon Sep 08, 2014 4:25 am  (#3)
Double check that you have the image mode set to RGB, like Ofnuts has said.
PostPosted: Mon Sep 08, 2014 5:06 am  (#4)
Thanks guys. I thought it had something to do with RGB. MY picture properties said RGB but the mode was on greyscale.
PostPosted: Mon Sep 08, 2014 5:50 am  (#5)
cron
