It is currently Wed Oct 28, 2026 7:13 am
 Post subject: Re: Send to Compress file not working:Help
PostPosted: Sun Oct 05, 2014 3:25 am  (#1)
conbagui wrote:
I tried as usual to right click send to Compress a pdf file and is giving me an error. :gaah Never happened before and I have not made any changes in my laptop. Can anyone help please...
I found this on Windows 7 Forums, but I'm not sure if this pertains to your OS.
Windows 7: Compressed zipped folders error
http://www.sevenforums.com/general-disc ... error.html
If you really need to compress something, I would suggest installing 7-zip or some other file compressor in the mean time.
I also found this, but I'm also not sure if this is the type of error you're experiencing.
Fix Compressed (Zipped) Folder Access Denied Error “Unable to Complete the Operation”
http://www.winhelponline.com/blog/fix-z ... operation/
PostPosted: Sun Oct 05, 2014 3:52 am  (#2)
If would help if you showed the actual error... IIRC you can use Ctrl-C in error message windows and this copies the error message to the clipboard.
PostPosted: Sun Oct 05, 2014 12:32 pm  (#3)
Do you get the same error compressing other file formats?
PostPosted: Sun Oct 05, 2014 10:13 pm  (#4)
If no files will compress this looks like a system problem. Have you had any other issues recently?
PostPosted: Mon Oct 06, 2014 2:04 am  (#5)
What is the compressed target? This error means the the target file is read-only because either:
  • it sits in a device that is read-only (check device for read-only switches)
  • it sits in a directory that is read-only (check the directory properties)
  • it is marked read-only (check its properties)
  • it is locked by some other process (should clear up by rebooting)
