It is currently Wed Oct 28, 2026 5:26 am
 Post subject: Focuswriter mini-review
PostPosted: Thu Nov 13, 2014 8:40 am  (#1)
As part of my NanoWriMo effort (see thread here) I have tried exploring some other ways of entering text than my normal go-tos VIM and LibreOffice. When writing prose I find I don't need the formatting buttons, tool box etc visible at every moment. I looked around and found Focuswriter.
This free text editor exists for Windows, Mac and Linux and I've found it really nice to work with. I pulled and compiled the latest development version off github, but there are stable binary packages/installers available for all operating systems on their homepage (and linux distros usually have it in their repositories).
For my NaNoWriMo effort I made myself a fantasy/book theme that looks like this:
(search Google-images for "focuswriter theme" to get more examples.).
As you can read in the screenshot above, Focuswriter is run in full-screen and you move your cursor to the edges of the screen to access menus (but most things can be done swiftly with keyboard shortcuts).
For NaNoWriMo it conveniently displays all information you need (I have a feeling NaNoWriMo influenced it a bit). It otherwise has all the basic text editor features you expect, like copy&paste, left/middle/right align, bold/cursive/underline, spell checking and things like that. It also allow you to mark blocks of text e.g. with "***" to separate "scenes". You then get a list with scenes you can quickly jump to or even rearrange in a different order if you change your mind about your story. It's still quite clear that this program is mainly aimed at the actual creation of the story though, not for the revision/postediting (for that a more full-featured formatting editor like libreoffice is better).
I also happen to be among those that really enjoy the optional typewriter sounds it can play when you type - it's a little gimicky but it really feels like you are getting things done! :)
Anyway, Focuswriter is small, fast and free - worth checking out if you enjoy writing.
Griatch
 Post subject: Re: Focuswriter mini-review
PostPosted: Fri Nov 14, 2014 3:15 am  (#2)
Updated the screenshot with correct referencing. :)
Griatch
PostPosted: Fri Nov 14, 2014 8:48 am  (#3)
Thank you Griatch. I'll find this very useful.
PostPosted: Fri Nov 14, 2014 10:44 am  (#4)
Ooo, this is nice!
PostPosted: Sat Nov 15, 2014 9:38 am  (#5)
@Erasian, Moko:
Yep, it's a nice little program indeed. :) And open-source to boot.
Griatch
PostPosted: Sat Nov 15, 2014 10:49 am  (#6)
Happily, focuswriter is available in the Fedora repositories. Just do yum install focuswriter. Other Linux users may want to check their version's repositories.
It takes a little getting used to. A bare, blank page confronts you when you open it. Move the mouse up to the top or bottom or left side and there are menu items, etc. I LOVE the typing sound. It's really nice not to be confronted with all those "helps" like you get in Word and in Writer. I always try to close out that stuff but can't seem to get them all turned off.
Griatch, did you copy and paste your text onto a bg? Trying to change the theme and the only thing I can import are images with an .fwtz extension.
PostPosted: Sat Nov 15, 2014 11:43 am  (#7)
Rather than Import (existing themes), use the New button in the Themes dialog.
Select the blank image under, Window Background.
PostPosted: Sat Nov 15, 2014 11:49 am  (#8)
@Oregonian
No, I didn't paste any text, my focuswriter setup does look like this when I write. You can only import/export themes as .fwtz. As Odinbc said, you need to create a new theme. You can also copy an existg theme and edit it. You can then select your own background, the margins, font-type, transparency etc to create your own theme (the theme edit menu looks short at first; remember that you can scroll down for more stuff).
At least the Linux Mint repository version of Focuswriter has a silly little bug that makes it type an "s" if you press ctrl+s when there is nothing to save. A minor thing but a little annoying. That's why I compiled the bleeding-edge version from github, which doesn't do that.
Griatch
PostPosted: Sat Nov 15, 2014 12:35 pm  (#9)
Thank you both so much. I downloaded it from APOD (Tulip Nebula - http://apod.nasa.gov/apod/ap141115.html ) and gave it a try. I was also happy I could enlarge the font.
BTW, Odin, that should be the "ADD" button.
PostPosted: Sat Nov 15, 2014 1:15 pm  (#10)
@Oregonian
Nice space-y theme. You should be able to press F11 to go into full-screen mode (to get rid of the window bar too).
Griatch
PostPosted: Sat Nov 15, 2014 2:27 pm  (#11)
Griatch wrote:
You should be able to press F11 to go into full-screen mode (to get rid of the window bar too). Griatch
Yes, I know. I deliberately shrank it for taking a screen shot. Thanks.
PostPosted: Sat Nov 15, 2014 4:44 pm  (#12)
Ah, I see. :)
Griatch
