It is currently Tue Oct 27, 2026 5:06 pm
 Post subject: Deleted Google Chrome By Mistake.
PostPosted: Sun Nov 23, 2014 2:55 pm  (#1)
Okay, here's the deal. I deleted Google Chrome by mistake and I want it back. Problem is, when I download it, it is in a completely different language other than English. I can't find the official download. I'm currently using Internet Explorer as a last resort and I have pop ups & ads all over the place with this one. I need help in finding the official English version of Google Chrome please. Any help would be great.
I probably have viruses on my laptop which don't help. Like I said, any help would be great.
Thanks.
 Post subject: Re: Deleted Google Chrome By Mistake.
PostPosted: Sun Nov 23, 2014 3:16 pm  (#2)
Google Chrome
Google Chrome for Windows
Firefox
PostPosted: Sun Nov 23, 2014 3:19 pm  (#3)
Molly, I tried it and I didn't get the English version. I got Chrome in another language.
PostPosted: Sun Nov 23, 2014 3:20 pm  (#4)
Firefox is also there, I use that.
PostPosted: Sun Nov 23, 2014 3:21 pm  (#5)
Have you tried
https://www.google.com/chrome/browser/?platform=win
check at the bottom right corner of that page for a language.
Otherwise a good replacement is SRware Iron, same as Chrome but with the phone home removed. I use in linux, I suppose the Win version works.
http://www.srware.net/en/software_srware_iron.php
PostPosted: Sun Nov 23, 2014 3:28 pm  (#6)
Or try this http://en.kioskea.net/download/download ... gle-chrome
PostPosted: Sun Nov 23, 2014 3:38 pm  (#7)
rich2005 wrote:
Have you tried
I tried the google chrome link and selected the language English, United States. When I downloaded and ran Google Chrome, it was not in English.
PostPosted: Sun Nov 23, 2014 3:52 pm  (#8)
mackenzieh wrote:
rich2005 wrote:
Have you tried
You stated that you think you may have a virus. Before you download anything or perform any installations, I suggest running a virus scan of some sort first.
PostPosted: Sun Nov 23, 2014 3:55 pm  (#9)
Google too clever for its own good :) It can determine location and OS to give you what it thinks you need. However California last time I looked was US.
It is probably a Win region issue, as another alternative, the portable version.
http://portableapps.com/apps/internet/g ... e_portable
PostPosted: Sun Nov 23, 2014 3:58 pm  (#10)
Go Firefox... :teeth Google sucks anyway, Ooops, just my opinion, IE is at the bottom of the ratings chart.
PostPosted: Sun Nov 23, 2014 4:10 pm  (#11)
mackenzieh wrote:
rich2005 wrote:
Have you tried
Wallace, I ran a Malaware Bytes scan and it found viruses and got rid of them. That still doesn't explain why I can't download Google Chrome in English.
PostPosted: Sun Nov 23, 2014 4:14 pm  (#12)
LOL! Molly. :) I will go back to firefox. I hope it works.
PostPosted: Sun Nov 23, 2014 4:26 pm  (#13)
I went back to firefox. Hopefully this browser won't let me down. :) is there anyway to block the ads that pop up on sites?
PostPosted: Sun Nov 23, 2014 5:04 pm  (#14)
Yes, look for Adblock.
PostPosted: Sun Nov 23, 2014 5:09 pm  (#15)
Adblock is great, I agree ^^^^^^^
PostPosted: Sun Nov 23, 2014 5:16 pm  (#16)
I installed Adblock plus 2.6.6. I hope that is the recent version.
PostPosted: Sun Nov 23, 2014 5:36 pm  (#17)
2.6.6 is the latest version. I also recommend a related plug that works in conjunction with adblock.
Adblock Plus Pop-up Addon 0.9.2
https://addons.mozilla.org/en-US/firefo ... -up-addon/
PostPosted: Sun Nov 23, 2014 5:44 pm  (#18)
Thanks GnuTux. I installed that as well. :)
PostPosted: Sun Nov 23, 2014 6:42 pm  (#19)
I would give AdBlock Edge a look, it's a fork of the Adblock Plus without the 'acceptable ads' feature. Yes, the 'acceptable ads' feature can be disabled but I switched to AdBlock Edge when Adblock Plus started enabling this so called 'feature' by default. They may have changed that policy now, but I'll stick with AdBlock Edge.
PostPosted: Sun Nov 23, 2014 7:23 pm  (#20)
conbagui wrote:
Hi Mackenzieh. If you still have the problem, you need to delete any chrome file on your user/your name/app/local folder and the C drive
I deleted Chrome all together. It was too much of a hassle.
cron
