It is currently Tue Oct 27, 2026 5:05 pm
 Post subject: Wallance
PostPosted: Wed Dec 03, 2014 2:23 pm  (#1)
I came up with an idea that might help you improve with doing your light source. After you create a graphic create a layer on top of your other layers name it light source then choose where you want it to come from. Then with a white or light color (use a radial or linear gradient) with the layer named light source. That way you'll be able to see where it's at. That's what I do. And practice. I love your purple xbox sphere.
I have things that I gotta work on myself like giving my graphics depth and getting them so they are not pixellated.
 Post subject: Re: Wallance
PostPosted: Wed Dec 03, 2014 2:34 pm  (#2)
Thanks for the tip Adventure, I'll have to try this out. And thanks for liking my "Purple" Xbox sphere. :bigthup
I don't do much work using the Gimp Lighting Effect, mainly as I haven't had much success with it yet.
PostPosted: Wed Dec 03, 2014 2:37 pm  (#3)
You will have success with it. I know you will. When I have the time I can do a simple tutorial.
PostPosted: Wed Dec 03, 2014 2:43 pm  (#4)
I'm happy that you have confidence in me. :hehe
A tut on this would be great. Not just for myself, but for the entire GC community. ;)
cron
