It is currently Tue Oct 27, 2026 7:26 am
 Post subject: Yay finally found a free screen capture program
PostPosted: Sat Dec 27, 2014 10:03 pm  (#1)
I found the screen capture program I was looking for. Now I can do video tutorials and speedart also. Don't have a mic though.
 Post subject: Re: Yay finally found a free screen capture program
PostPosted: Sat Dec 27, 2014 10:44 pm  (#2)
What program might that be? I use Screencast-o-Matic myself.
PostPosted: Sun Dec 28, 2014 7:50 am  (#3)
I use FastStone Capture for stills and also movies if need be.
PostPosted: Sun Dec 28, 2014 8:04 am  (#4)
I have FastStone Image Viewer so I can view GIF image in windows 7. You must have another version of the program if your able to make videos, or are you saying that you watch movies with it?
PostPosted: Sun Dec 28, 2014 4:08 pm  (#5)
FastStone Capture is a separate program from the viewer/manager, at least it use to be. When I was running windows I used both.
PostPosted: Sun Dec 28, 2014 4:18 pm  (#6)
I wasn't really looking for a screen capture program, but now it has piqued my interest.
PostPosted: Sun Dec 28, 2014 9:51 pm  (#7)
I got ezvid.
PostPosted: Sun Dec 28, 2014 10:17 pm  (#8)
Adventure wrote:
I got ezvid.
Oh okay, I haven't heard of that program. Good luck with it. :bigthup
PostPosted: Mon Dec 29, 2014 4:36 am  (#9)
last freeware version (for non-commercial use)
http://www.321download.com/LastFreeware ... #FastStone Capture
edit: To avoid confusion this is just a screen capture, not a screen recorder, that came in later versions as noted by rod and costs $$$
PostPosted: Mon Dec 29, 2014 12:16 pm  (#10)
Yes i use the commercial lifetime license version here which allows screen recording with mic or speaker audio. A very small but powerful program with a small fingerprint. All updates are free forever.
http://www.faststone.org/FSCaptureDetail.htm Price is 20.00.
In fact i just updated to 8.0
Version 8.0 (December 19, 2014)
Added "Fixed-Size Region" to the screen video recorder
Added animated GIF converter to the screen video editor. This allows you to convert your screen videos to animated gif files, which are supported by most web browsers
Now you can drag and move the yellow control bar for screen video recording
Other minor improvements
In my opinion it's a great tool. And it isn't too pricey. :)
PostPosted: Mon Dec 29, 2014 1:56 pm  (#11)
The price point and free updates forever sounds really great, only having to make the initial purchase is also a big plus.
I'll need to check that out. Thanks Rod! :bigthup
PostPosted: Mon Dec 29, 2014 7:21 pm  (#12)
I have found over the years "free upgrades for life" aren't what they are suppose to be, unless they are talking about the life of a fly of beetle. For example, years ago I purchased Winzip with the same "free upgrades for life". That was until version 9 when they stopped free upgrades.
PostPosted: Mon Dec 29, 2014 8:20 pm  (#13)
I think you make a good point, but we all take our changes whit this kind of promise. As they say... "Sh*t Happens".
PostPosted: Tue Dec 30, 2014 5:07 pm  (#14)
Well i bought it when it was 6.8 and that was 2010 or 11 so since then i have spent nothing on it. Of course back then i paid 10.00 USD.
