in your image there are two problems:
1-selecting by color each character is not easy because the black is not pure and uniform black
2-the characters are not at a correct distance one from the others
Thus my suggestion is to OVERRIDE each character with a similar one and with the color you like.
So I did the following in preparation of your task:
1-identifying the character set (I found one similar, but not equal: Garamond)
2-preparing 3 layers one for each character and positioning the characters so that they override the existing ones
I attach here 2 different xcf, the first one (workfile) you should use for accomplishing your modifications
the second one is an example just to show the result (I choose random colors, only to show)
The two files are also repeated in png, so that you can see them immediately
workfile.xcf [714.73 KiB]
Downloaded 195 times
example.xcf [723.13 KiB]
Downloaded 191 times
next post for the png version
