It is currently Wed Oct 28, 2026 1:12 pm
 Post subject: Backwards Bicycle
PostPosted: Tue Apr 28, 2015 12:26 am  (#1)
Since I ride my bike nearly every day. I found this video to be quite interesting.
 Post subject: Re: Backwards Bicycle
PostPosted: Tue Apr 28, 2015 2:04 am  (#2)
Thanks Wallace, very informative video especially at the end.
PostPosted: Tue Apr 28, 2015 3:47 am  (#3)
Well, anyone who rides a motorcycle knows that above some speed you have to reverse-steer (ie, push on the side where you want to go). This is also true of pedal bikes, btw :)
PostPosted: Tue Apr 28, 2015 5:04 am  (#4)
It's called Counter Steering.
When riding a bicycle or a motorcycle, counter steering is a method of preparing for a turn by a small, momentary turn of the handlebars in the opposite direction. The necessity to counter steer becomes noticeable above a minimum speed. A bike can negotiate a curve only when it leans towards the inside of the turn, at a camber angle appropriate for the velocity and the sharpness of the turn. At higher velocities, the bike has a strong natural tendency to remain upright.
The transition of riding in a straight line to negotiating a turn is a process of shifting the balance of the bike. In a sense, the bike needs to be thrown off balance first.
If a biker wants to turn to the right, he first throws the bike off balance by a well-timed jolt to the handlebars, momentarily pointing the front wheel slightly to the left.
As the bike is being tipped over to the right (by centrifugal forces) the front wheel is steered into the curve, and the curve is negotiated with the proper inward lean. This process requires little physical effort, because the geometry of the steering of a bike is designed in such a way that the front wheel has a strong tendency to follow the balance of the bike.
Counter steering is indispensable for motorcycle steering. Most people are not consciously aware that they employ counter steering when riding their bicycle. Their body has learned to include the well timed counter steering jolt, they have learned to do so while learning to ride a bicycle in childhood. Often people simply assume that the steering of a bicycle is just like the steering of a car. Their subconscious balance skills know better: they shift their balance first, and then the front wheel tends to steer into the turn that the rider has in mind.
Even more so than on a bicycle, mastering the technique of counter steering is essential for safe motorcycle riding. Above around 10 mph, it is not possible to conventionally steer a motorcycle and counter steering is used exclusively to change direction. Much of the art of motorcycle cornering is learning how to effectively "push" the grips into corners and how to maintain proper lean angles through the turn.
PostPosted: Tue Apr 28, 2015 8:24 am  (#5)
Thanks for sharing Wallace.
PostPosted: Tue Apr 28, 2015 1:40 pm  (#6)
You're welcome sallyanne. :bigthup
