trandoductin wrote:
this would be great for taking photos of wildlife since you can zoom the heck out of it without scaring the animal away. like birds in the trees.
Been there and done that... in practice theses cameras are much too slow for wildlife. The birds have very good eyes. They see you, they watch you. As long as you don't look at them, they are fine. But it you start looking at them they hide or fly away. So you have to take them a bit by surprise, and that requires a quick camera (zoom, and autofocus). The electric zoom is too slow, and no, you can't have a potshot aim with a 600mm(*) lens and expect the bird to be in the frame, and if it's not in the frame you won't find it by just wiggling the lens. So you start your aim with something wider, and zoom in. A couple of seconds with an electric zoom. And then you pray for the autofocus to do its job before the bird flies away (add another second or so). And then you find that autofocus locked on a twig instead of the bird so you try to go manual for the next pictures. But the camera isn't really build to make that fast, and the EVF(**) is not fine enough... Last, the sensor lacks sensitivity so the shutter time will be long. And none of the shake prevention mechanisms will have an effect on a moving subject.
Now, of course, if you are in its blind spot because you have the sun in your back, things are different.
(*) "35mm equivalent" focal length...
(**) forget about the screen on the back, you won't hold the camera at arm's length...
