It is currently Wed Oct 28, 2026 3:00 pm
 Post subject: Yes; I do go where angels fear to tread.
PostPosted: Wed Jul 29, 2015 8:23 am  (#1)
Installed Win10 this morning. More then a few bugs; just got my XP VM (typing this message now in it) up and running, but no sound (yes; I re-installed the guest additions but to no avail). I suspect it has to do with Virtualbox and I will have to wait for a VB update to get it working again unfortunately (had to run a repair even to get my VB to work). Right now, my Win7 VM is also hosed. Hoping that an update to VB fixes that issue too. Office 2013, Photoshop, and GIMP (GIMP took a little while since it had to refresh the fonts cache which is a long process in GIMP as a few of you already know) but those programs worked fine. I already had a crash too (Virtualbox caused it) require a hard (power button) re-boot. I think running the repair fixed the issue; time will tell. Unless you are game, I would hold off on the upgrade until other folks like me ferret out the bugs. lol
 Post subject: Re: Yes; I do go where angels fear to tread.
PostPosted: Wed Jul 29, 2015 8:36 am  (#2)
As I'm being continuously reminded in Morrowind; "You like to dance close to the fire, don't you?" :hexer
PostPosted: Wed Jul 29, 2015 8:57 am  (#3)
Is virtual box included in the install? I don't think I have it yet.
PostPosted: Wed Jul 29, 2015 10:28 am  (#4)
Update:
For some reason, my Win7 VM is now working (there were two additional Win10 updates pushed after the initial install that might have repaired it; who really knows). Still, none of my VMs (WinXP, Win7, or Ubuntu) has sound. I suspect it's with an interaction between Virtualbox and Win10. Win10's soundmixer shows up for the VM, but sliding the slider does nada. Oh well. Can wait. :)
PostPosted: Wed Jul 29, 2015 2:12 pm  (#5)
I get this message whenever I click on the "Get Windows 10 icon"...
PostPosted: Wed Jul 29, 2015 7:59 pm  (#6)
I vaguely remember that screen Wallace. Not sure what I did to continue on with the install. I will say expect your Virtualbox to be very flaky. I just finished doing another hard reboot of Win10 since if froze again after waking up from hibernate. I suppose I will just shut down my VM completely prior to hibernation to see if I get an acceptable result. Sure do hope Oracle repairs the issues with Win10 compatibility. Every other program I have works great with Win10 with no issues thus far. :)
PostPosted: Wed Jul 29, 2015 9:10 pm  (#7)
That's good to know.
I'm going to wait a while to install win10. My download hasn't shown yet, but I've received a few emails form Microsoft stating that it will happen soon.
PostPosted: Thu Jul 30, 2015 2:24 am  (#8)
Just remembered when Sallyanne asked. I checked my update history in Win8.1 and it said it failed to install Win10. While there, I saw an option to install upgrade as I recall. :)
PostPosted: Thu Jul 30, 2015 2:27 am  (#9)
I have yet to get Windows 10. I like Windows 7 and I will continue to use it until my laptop completely gives out. I have no reason to upgrade my laptop unless at some point or another I some how am forced into upgrading it.
PostPosted: Thu Jul 30, 2015 6:57 am  (#10)
Got my win10 download. Should I install or wait? :puzzled
PostPosted: Thu Jul 30, 2015 1:19 pm  (#11)
If you like Virtualbox, I would wait until Oracle pushes another update since Win10 don't play well with VB right now. I cannot use Windows hibernate or sleep mode for instance period since, if I wake my PC up from either, and have VB on, it will give me an error and is useless (even if I close and re-opend) until I reboot which means I'm going old school now and shutting off my computer instead. No sound in any of my VMs either and I'm not the only one experiencing this issue (trust me). :)
https://forums.xamarin.com/discussion/4 ... and-images
https://forums.virtualbox.org/viewtopic ... 30#p330089
PostPosted: Thu Jul 30, 2015 1:40 pm  (#12)
When the windows 10 arrives, how do you know it is here? Does it come in a Email?
PostPosted: Thu Jul 30, 2015 1:48 pm  (#13)
It's personally delivered by Bill Gates.:hehe
PostPosted: Thu Jul 30, 2015 1:55 pm  (#14)
Check your update history Molly. Mine actually told me that Windows failed to upgrade to Win10 which told me the files were on my PC. I clicked around the error within Update History and clicked a link to install the upgrade as I recall. Chances are, you already have the files too. :)
To Tux; way too funny. ;)
PostPosted: Fri Jul 31, 2015 1:25 pm  (#15)
OK; first , I didn't do anything. I did boot into my XP VM and still did not get the startup sound. While browsing a Yahoo story, all of a sudden I heard one of the Yahoo ads. Again, I did not do a thing. I re-started my XP VM and got both the closing sound and starting sound. So far so good. I then decided to test Win10 hiberation to see if it will hose Virtualbox. It did not. I'm really getting stoked now. Hopefully somehow M$ implemented a fix that didn't even require a reboot; still don't like things that fix themselves, but I'll accept this fix. Hopefully Win10 can only get better from now on. :)
edit: (7/31/2015)
Spoke to soon; now after crash, no sound again. :(
edit (8/1/2015)
Sounds back (but for how long? lol). :)
 Post subject: Re: Yes; I do go where angels fear to tread. Lucky guy I am.
PostPosted: Mon Aug 10, 2015 3:59 pm  (#16)
OK; again I go where angels fear to tread. I'm tired of the instability issues with Hibernate/sleep and Virtualbox. I could not find anywhere others experiencing this. Yes; found more then many people experiencing audio issues with VB. Decided to download the MB Drivers from my system's (ASUS) site for Win10 and part of the installation was something called USB filter. Well, during the install, I lost my mouse and keyboard and waited a good while before the driver started to actually install this driver. It still wouldn't go on to the next set of installs, so, after 40 minutes, I hard-key power downed. When I powered up, my system was still stable (thankyou God; lol). I then ran my VM and tested hibernate/wake up. No problem now (yippee). Then I tested sleep/wakeup. Still no problem (yippee). Drastic step for me but I did create a system recovery point before doing this, but if my system wouldn't have rebooted, I would hope my recovery boot CD would have allowed me to recover, but sphewwwww; glad I didn't have to do that. Still have no sound, so I believe that issue is with VirtualBox (funny; if I leave my VM on for a few hours, sometimes my VM sound will work). Happy I am now. Hopefully my system won't crash when M$ updates next. lol
edit:
Spoke a little too soon. :(
Still, at least VB doesn't crash Win10 anymore. I know what I have to do and still be able to hibernate/sleep without having to reboot. Still, I wish some entity would fix this. Not sure how installing the VGA/USB Driver from Asus made my system a bit more stable, but, it did. Hopefully it will get better when these bugs get addressed. Had several Watchdog timer resets which, I assume, the report gets sent to M$ to see what can be optimized on their end. We shall see. :)
PostPosted: Tue Aug 11, 2015 9:45 pm  (#17)
OK; someone posted a work-a-round for the no sound in VM issue. Just tested this solution and it works. Better then what I was using (waiting for a few hours and praying my XP VM's sound would magically show up; lol). :)
https://www.virtualbox.org/ticket/14361#comment:12
PostPosted: Tue Aug 11, 2015 9:52 pm  (#18)
Good luck, you may need to wait a while, but then again what do I know. :mrgreen:
PostPosted: Tue Aug 11, 2015 10:44 pm  (#19)
I still cannot put my system in sleep or hibernate though with Virtualbox running Wallace; it will crash my system (no joke; actually crashes Win10 with a DPC_WATCHDOG_VIOLATION error (basically, the processor gets overwhelmed; I have an 8-core; to crash my system (and I only have 2 cpus dedicated to my VM), says a lot. lol
PostPosted: Fri Aug 14, 2015 11:14 pm  (#20)
Just a happy update. I did install the 10.0.1x beta (Virtualbox) which seems to be working fine (even in Hibernate and sleep modes) now. Oracle stated that 10.0.2x was still not compatible with Win10 so holding off installing it for now and sticking w/ the beta. Sound now works too without doing shenanigans. Pretty stoked. I figure things would start to work soon enough. Liking Win10 overall. Very quick boot. Not sure how to get Cortana to talk to me though; I don't have a mic so type my request and get a good but silent answer. lol
Oh well. :)
