It is currently Wed Oct 28, 2026 2:32 am
 Post subject: adds on screen
PostPosted: Thu Jul 30, 2015 9:29 pm  (#1)
How do I get rid of these
 Post subject: Re: adds on screen
PostPosted: Thu Jul 30, 2015 9:53 pm  (#2)
I'll be they are gone
PostPosted: Fri Jul 31, 2015 1:43 am  (#3)
I had some annoying adds on in the forum and today they are missing. Did you get them out? if so, Well done! Thank you :tyspin
PostPosted: Fri Jul 31, 2015 3:55 am  (#4)
You will only see ads if you're NOT logged-in.
PostPosted: Fri Jul 31, 2015 4:58 am  (#5)
jontait2 you are correct, as soon as you log in the adds dissappear
PostPosted: Fri Jul 31, 2015 3:02 pm  (#6)
... and you aren't running something like AdBlock+ :)
PostPosted: Fri Jul 31, 2015 8:09 pm  (#7)
Thanx Ofnuts, I now have AdBlock+ and it is working well
PostPosted: Fri Jul 31, 2015 8:18 pm  (#8)
I use Privoxy; never see ads. Had to add a special rule so I could see the top Image bar though (like the Image Bar since clicking on it gets me to the main page). :)
PostPosted: Fri Jul 31, 2015 8:27 pm  (#9)
Adblock Edge is the one you want, their philosophy is less evil.
PostPosted: Fri Jul 31, 2015 11:40 pm  (#10)
I see. they are creeping in between posts.....well before I was logged in I could see them.
PostPosted: Sun Aug 02, 2015 1:03 am  (#11)
I would like to hear from Those running the site if other changes to the site will also be made :hoh
