nixnine wrote:
I switched from firefox to chrome after it started crashing on me.
The problem started with me when I removed flash and switched to HTML5, which I intend to keep using from now on. It must be the libs required to play MP4 files that are causing the crashes with Firefox.
Migrating to the newer version of my OS will be no easy task, it's a 10GB savefile that I need to re-create and that'll take weeks.
I'm sticking to my original OS for now, and have switched to Opera as a transitional browser. So far no crashes at all with it. Latest version is Chrome based, so I might give that a go as well.
