It is currently Wed Oct 28, 2026 6:57 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: to fellow script coders.
PostPosted: Sun Sep 20, 2015 12:32 pm  (#1)
Are you ever in a mood or have the urge to write (I usually do a lot of cutting and pasting) a scheme script?
I am having that mood right now..but have no idea what to write hehehe.
It's a strong urge right now though almost like a hunger.
I just wish i had something to write like not too easy, but not too difficult either.
 Post subject: Re: to fellow script coders.
PostPosted: Sun Sep 20, 2015 12:42 pm  (#2)
Now you come to mention it..
There was a new user on gimpforums.com asking for a camera shutter transition effect to use in between video sequences.
A quick search revealed this old tute on gimptalk:
http://www.gimptalk.com/index.php?/topi ... iris-tute/
But I reckon that could be done better (and with lots more styles and options) in a good script.
Just a thought.
PostPosted: Sun Sep 20, 2015 1:04 pm  (#3)
maybe i'll save that for a keener day :hehe
I don't feel that keen right now.
PostPosted: Sun Sep 20, 2015 4:11 pm  (#4)
My family has instructions to kill me on the spot if this ever happens.
But a Python script, yes... in fact I thought about a script all weekend. But then I convinced myself that the math was against me, the script was not workable.
PostPosted: Sun Sep 20, 2015 4:53 pm  (#5)
:hehe
PostPosted: Mon Sep 21, 2015 6:58 am  (#6)
:) :lol
How about a really nice lens flare script?
PostPosted: Mon Sep 21, 2015 8:52 pm  (#7)
Oh yes, lens flares with slider bars for lots of parameters!
PostPosted: Mon Sep 21, 2015 10:26 pm  (#8)
There's this thing that I do all the time that I wish could be made into a script.
1. I start with a pen line.
2. Go into Quick Mask and invert it so that the red is gone.
3. Select Default black foreground.
4. go to [Edit] [stroke path] no antialiasing line width of 1
5. Select the red line and use [Select] [Border] on it and change the pixels to any number that suits me and use feather boarder. (this gives me a nice even increase in pixels from red in the middle to opaque around the sides after I paist in the foreground color to it).
6. Then I use a saved curve on the quick mask canvas to make the increase in pixels go rounded from opaque to red (kind of rounded inward to a sharp peak.
7. Then I invert the quick mask and exit.
I use these kinds of selections along with the airbrush tool to put creases into colors etc. Like in this image, I used it on the fingers and elbows etc.
PostPosted: Mon Sep 21, 2015 10:51 pm  (#9)
I don't know enough to even perform these steps myself.
PostPosted: Tue Sep 22, 2015 8:54 am  (#10)
It's all done to make a sharp edged selection which I then use as a mask to lighten up or create creases using the air brush. I could try to explain it step by step with images.
PostPosted: Tue Sep 22, 2015 11:34 am  (#11)
yeah that would help, if you can help me understand step by step and i can do it manually myself,
that would help in writing the script :hehe
PostPosted: Tue Sep 22, 2015 9:28 pm  (#12)
can't wait to see explaination with images so i can get started. :)
PostPosted: Tue Sep 22, 2015 9:56 pm  (#13)
I'll put something together tomorrow. Kind of late right now.
PostPosted: Tue Sep 22, 2015 10:23 pm  (#14)
okay :(
PostPosted: Wed Sep 23, 2015 9:05 am  (#15)
If this script is possible maybe it would be easier to have the script use a layer instead of quick mask like this:
1. Here's the path that I want to turn into a sharp selection:
2. Create a new white layer:
3. Stroke the path with no antialiasing and a line width of 1px:
PostPosted: Wed Sep 23, 2015 9:06 am  (#16)
4. Color Menu [Color to Alpha]:
5. Layer Menu [Transparency] [Alpha to Selection]:
6. [Selection] [Border] This needs to be interactive:
PostPosted: Wed Sep 23, 2015 9:08 am  (#17)
7. Delete the active layer and create a new white layer:
8. Then paste in the default black forground color [Edit] [Fill with FG Color] (maybe the script can do a "D" foreground black background white first):
9. Unselect all [Ctrl+A].
10. Do a Curves function with a saved preset curve like this one to make the color sharp to a point of black:
11. Then do a color to alpha [Colors] [Color to Alpha].
12. Then a [Layer] [Transparency] [Alpha to Selection].
PostPosted: Wed Sep 23, 2015 9:08 am  (#18)
13. Then just delete the layer and your left with a sharp selection mask that can be used to draw creases etc.
PostPosted: Wed Sep 23, 2015 9:51 am  (#19)
I've just found that if you can use the quick mask in the script it would cut down the number of steps signigficantly.
1. Start with a path and go to quick mask mode and turn the forground color to white [ "D" then "X"] and then perform a Stroke Path on it with no antialiasing and 1px:
2. Go out of Quick Mask and perform the [Select] [Border] function on it which would need to be interactive:
3. Then go back into quick mask mode and perform the curves function on it to make it sharp:
4. Then just exit quick mask mode and you have a selection ready to go.
PostPosted: Wed Sep 23, 2015 11:42 am  (#20)
i am trying to do your 1st method manually and was confused about step 13.
after i do alpha to selection and deleted i am left with this.
is that right or did i miss something.
