It is currently Fri Oct 16, 2026 8:46 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: paint by numbers.
PostPosted: Sun Sep 20, 2015 12:54 pm  (#1)
i was going for the paint by numbers look...
should've made my strokes thinner.
Edit: maybe this one is better
 Post subject: Re: paint by numbers.
PostPosted: Sun Sep 20, 2015 8:16 pm  (#2)
the colors give it sort of a camo look!
PostPosted: Sun Sep 20, 2015 11:47 pm  (#3)
I think the one with the thinner black lines looks pretty good, that would be the bottom one. :bigthup
PostPosted: Mon Sep 21, 2015 5:12 am  (#4)
:kpix I like the thicker line version as it more reflects the large, heavy and rough appearance of an elephant
PostPosted: Mon Sep 21, 2015 9:02 am  (#5)
trandoductin: the botttom one definitely has that paint by numbers look, but i agree with steve about the thicker lines working better with the elephant, i like that one better at least :). nice results either case, well done.
PostPosted: Mon Sep 21, 2015 11:01 am  (#6)
how's this one? I personally like it more than the other two. since it's not too thick and not too thin either (stroke path 2px width).
PostPosted: Mon Sep 21, 2015 11:24 am  (#7)
yes, Tin, the third one looks as the best
but ... I have a stupid question:
what's the advantage over cartoonize?
(I tell you the truth: I didn't understand the technique....hehehe)
PostPosted: Mon Sep 21, 2015 1:20 pm  (#8)
i didn't know cartoonize did the same (don't know if it does).
How i did it is pretty simple, indexed color then pick number of colors, then pick each color, and turn to path, then stroke path.
PostPosted: Mon Sep 21, 2015 5:46 pm  (#9)
created a simple script for this simple task of stroking paths of a reduced colored image.
The script will be available under Script-Fu/Create-New/Paint By Numbers...
paint-by-numbers.scm [3.98 KiB]
Downloaded 379 times
PostPosted: Mon Sep 21, 2015 11:51 pm  (#10)
trandoductin: see you found something to cure your script writing itch with :). i like the third elephant best too. i don't know if cartooniser works exactly like this, but it looks very much like it.
PostPosted: Tue Sep 22, 2015 12:27 am  (#11)
thanks for the script, Tin
PostPosted: Tue Sep 22, 2015 4:06 am  (#12)
Here's my go at it, minus the stroked lines.
@ Trandoductin, can an option to not use lines be added, and or be able to place the lines on it's own layer?
PostPosted: Tue Sep 22, 2015 6:39 am  (#13)
A fine script :bigthup , tried it on a few subjects, building, statue, goose and
Autumn leaves
PostPosted: Tue Sep 22, 2015 8:22 am  (#14)
Here's another I did.
Is that cool or what! :jumpclap
PostPosted: Tue Sep 22, 2015 9:40 am  (#15)
cool Wallace!
what about this "variation"? (you left the BG to the taste of those who look at the picture, hehehe...)
PostPosted: Tue Sep 22, 2015 10:54 am  (#16)
cool Wallace!
That's interesting. :mrgreen:
PostPosted: Tue Sep 22, 2015 11:54 am  (#17)
The attachment PBY#.PNG is no longer available
thanks for suggesting that Wallace..I think it's good option to this simple script even though if you uncheck the "Create Lines" option, the script does very little work :D
here it is
paint-by-numbers.scm [4.25 KiB]
Downloaded 302 times
PostPosted: Tue Sep 22, 2015 11:55 am  (#18)
yes it helped cured my itch :hi5
PostPosted: Tue Sep 22, 2015 12:00 pm  (#19)
You're welcome T and nice work. :bigthup
PostPosted: Tue Sep 22, 2015 12:51 pm  (#20)
dinasset, thanks for trying out my script.
Steve, it looks like your out line of the autumn leaves is thicker than the lines that separated the shades of leaves. Did you pick a path of sky and stroked it yourself or something?
