It is currently Wed Oct 28, 2026 7:48 pm
 Post subject: How to create links in Fedora Mate desktop[Solved, thanks everyone]
PostPosted: Wed Nov 25, 2015 1:32 pm  (#1)
I want to create some links on my desktop in Fedora 21 Mate desktop. Suppose I want a link to Gimp Chat, how would I go about that? Thanks
 Post subject: Re: How to create links in Fedora Mate desktop
PostPosted: Wed Nov 25, 2015 2:19 pm  (#2)
Open Gimp Chat with Firefox
Click right mouse button over bookmarks (star)
Select Save as... (I tried it with all files at the bottom options, it works)
Then you have to get a .html file in your desktop.
I think that may be possible add an icon (use propierties menu by clicking over html icon)
PostPosted: Wed Nov 25, 2015 2:22 pm  (#3)
Thanks jamac4k, I will try that.
I don't see a save or a save as, could you do me a screen shot of what you did, I still can't figure it out. thanks
PostPosted: Wed Nov 25, 2015 2:53 pm  (#4)
I am not on fedora but this sounds like it makes sense.
https://ask.fedoraproject.org/en/question/64212/how-can-i-shortcut-a-website-into-an-application/
on windows, i did something similar and it worked.
I just made a short cut to firefox
then right clicked and edited properties and added http://gimpchat.com after quoted string in target
so that my target became
"C:\Program Files (x86)\Mozilla Firefox\firefox.exe" http://gimpchat.com
and it worked. so i imagine the above link would also work for fedora.
not sure if you can edit properties in fedora or not or you have to text edit it.
PostPosted: Wed Nov 25, 2015 3:16 pm  (#5)
I will also try that Tran, thanks. I know it works in windows.
PostPosted: Wed Nov 25, 2015 3:29 pm  (#6)
What you need is a desktop file something.desktop which is a plain text file along the lines of this
[Desktop Entry]
Version=1.0
Terminal=false
Type=Application
Name=Gimpchat
Exec=firefox http://www.gimpchat.com
Icon=firefox
It should be set as executable and goes in your home folder ~/Desktop
something like this
PostPosted: Wed Nov 25, 2015 5:08 pm  (#7)
Rich that may work but if you are using FF you can just pull the little icon out onto your desktop and it will create a url to gimp chat
Apparently, it doesn't work with Chrome
This is my link to Gimp Chat on my desktop
PostPosted: Wed Nov 25, 2015 6:09 pm  (#8)
Molly:
Use the Create launcher better:
PostPosted: Wed Nov 25, 2015 6:12 pm  (#9)
Are you using FF or Chrome jamac4k
For Chrome users, here is the link for creating a url link for your desktop
Create a url link for desktop using Chrome
 Post subject: Re: How to create links in Fedora Mate desktop[Solved, thanks everyone
PostPosted: Wed Nov 25, 2015 8:47 pm  (#10)
Image_Image
PostPosted: Thu Nov 26, 2015 2:42 am  (#11)
Molly:
I use Firefox (or Iceweasel) as default. Chromiun (not Chrome) and Qupzilla also.
PostPosted: Thu Nov 26, 2015 4:13 am  (#12)
Just in case anyone gets confused.
I did not pull anything onto the desktop.
Creating a .desktop file is real basic linux, if you have some shell that does it for you great, but you still end up with a .desktop file.
The icon depends on you, a quick demo and I kept the Firefox icon. Make an icon and put the full path to it in the icon= line in the .desktop file.
I used Firefox (had to install it) as I thought that was the browser being used. The same format is used for any application that will run.
