It is currently Wed Oct 28, 2026 11:02 pm
 Post subject: themes
PostPosted: Wed Mar 16, 2011 6:30 am  (#1)
I liked gimpthemes 1.0 for windows but is there anything like it for Linux? I really liked some of the dark themes. I've been googling myself senseless and have been lurking in the Mint forum but haven't found a satisfactory answer.
 Post subject: Re: themes
PostPosted: Wed Mar 16, 2011 8:16 am  (#2)
Last i heard there was some kind of development for a plug-in to create themes on the fly through GTK or pixbuf, or their was supposed to be
Doesn't linux have more theme options? Grab the windows version and just use the themes folders and write them into your gtkrc, that's all the program (themes 1.0 does).
I could upload all the themes folders if you would like? I think they will work on windows or linux.
PostPosted: Wed Mar 16, 2011 8:24 am  (#3)
Here you go
you will find these themes inside the zip
Themes for Gimp.zip [193.46 KiB]
Downloaded 179 times
PostPosted: Wed Mar 16, 2011 12:09 pm  (#4)
I tried that and it didn't work, I checked in the Mint forum and another person tried it and it didn't work for them either. That doesn't make sense to me so I'm going to do it again this evening. last night when i tried i was zombie tired and full of drugs so i might not have done it right or put them in the wrong place in Linux. Common sense says it should work.
PostPosted: Wed Mar 16, 2011 12:32 pm  (#5)
Update, I have them in the right place now. They're listed in the themes when I go to preferences but regardless of which one I try to use nothing changes. I tried restarting Gimp thinkng that might be necessary but to no avail. Woe is me.
PostPosted: Wed Mar 16, 2011 12:49 pm  (#6)
all gtk themes should work there is a gnome webside witgh hundreds of them, but the problem may be that the themes require also the engine to be installed..
as example theme x, y, z, y may require the X engine, other the Y engine
replace letters with the real names
Only big difference Linux /Win in windows change theme will change only the gimp look, in linux may change the look of everything or at least of a lot of programs
PostPosted: Wed Mar 16, 2011 3:53 pm  (#7)
Hmmm, ok thanks, I'll research it some more.
PostPosted: Wed Mar 16, 2011 10:00 pm  (#8)
That's probably why the exe comes with a binary for windows then.I thought it was just an engine to write to the gtkrc file.
Thanks PC. :)
Gms9810 did you try to just add the path to the theme in Edit/Pref and then write the theme in the gtkr manually?
If that doesn't work add the theme path in Edit/Pref then delete the gtkrc file.Restart Gimp.Then you may still need to select the theme and restart Gimp again.
Overwriting the gtkrc file should do it though.
PostPosted: Thu Mar 17, 2011 8:30 am  (#9)
Thanks PC. :)
I tried putting them in a folder that I made and that didn't work so I put them in he folder already listed in the prefs. I don't know how to do the stuff with the gtkrc file.
PostPosted: Thu Mar 17, 2011 8:50 am  (#10)
You probably need the engine for them anyways Gms9810.
I didn't realize the binary was for more than just writing to the rc files.
Sorry
Still GTK should recognize them. I bet there is a way around it somehow.
I do not use your system though so no way for me to test and upload a good working install for you.
Someone with your platform will have to do it for you.
PostPosted: Thu Mar 17, 2011 10:57 am  (#11)
Gms9810
I have this in /etc/gimp/2.0/gtkrc
# pixmap_path "<dir 1>:<dir 2>:<dir 3>:..."
# include "rc-file"
# style <name> [= <name>]
# <option>
# widget <widget_set> style <style_name>
# class <widget_class_set> style <style_name>
# You can add your own GIMP-specific GTK styles here.
# Adjust the size of previews in plug-in dialogs:
style "gimp-large-preview"
GimpPreview::size = 256
# class "GimpPreview" style "gimp-large-preview"
# Change the dock separator DND highlight color:
style "gimp-red-separator-style"
bg[SELECTED] = "#aa2448"
# widget "*gimp-dock-separator*" style "gimp-red-separator-style"
I unzipped the gtk files, better read what is in them.
To make life easier install "mc" to browse files.
For instance unzipping a file is simply put the mc cursor over it and hitting enter.
Hope this gets you going.
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Fri Mar 18, 2011 2:39 am  (#12)
I have a sneaky feeling these dll files have a lot to do with running the theme engines for each theme.
These are all found in the engines folder after installing themes 1.0 :)
I am not entirely sure if these dll files will work in Linux.I attached them in a zip.
They go in - C:\Program Files\GIMP-2.0\lib\gtk-2.0\2.10.0\engines in windows xp not sure where they would go in Linux but most likely the same folder.
File comment: Theme program dynamic link libraries
Theme-DLLs.zip [819.8 KiB]
Downloaded 152 times
PostPosted: Fri Mar 18, 2011 2:57 am  (#13)
Dll's for Windows will not work in Linux.
I d/led them and checked the contents.
They are Windows executables which will only work through Wine in Linux.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Fri Mar 18, 2011 3:30 am  (#14)
Argh - sorry gerard82 :\
PostPosted: Fri Mar 18, 2011 4:19 am  (#15)
They even may work in theory,
but any attempt to run in Linux a native Linux desktop thank to Window dll loaded by Wine :hehe would provoke in all linux entusiast a endless series of jokes and sarcasm :rofl ...i believe would became as a myth or a urban legend and bring if not respect at least a huge notoriety in the Unix word to the project leader and all his staff
and maybe even a Nobel Prize ( for the Goofest Hack of the New Millenium )
Please no any pun intended i'm a bit hight now (mostly because sleepless from 48 h ) i imagined the faces of many Unix geeks in front to a similar hack ...and the idea was just too funny for me
i tryed to Google for the first engine but i only found a rpm version http://rpm.pbone.net/index.php3/stat/4/ ... 6.rpm.html
and that peculiar engine is marked as obsolete
i find some for ubuntu http://packages.ubuntu.com/lucid/x11/gt ... nes-aurora
gtk-engine and libgtk-engine ( may be possible keyword for search
PostPosted: Fri Mar 18, 2011 6:23 am  (#16)
For confirmed Windows users:
Windows executables can only run in Linux through an emulator (Wine = WindowsEmulator).
Directory structure is very different too.
Linux is a clone of Unix, a very professional OS written by professionals.
What follows is the directory structure of Linux.
Some distro's may deviate a little from what follows.
/bin: system only software
/boot: kernel + booting software (grub or lilo)
/dev: devices (mostly hardware)
/etc: system wide configuration files + init software.
/home: here user(s) files including private configs.
/lib: system libraries (comparable to dll's in Windows;most not for user programs)
/media: empty until you pop in a USB stick or a cd.
/mnt: cd/dvd and other media manually "mounted".
/opt: optional user software usually proprietary stuff like Flash.
/proc: process info used system wide.
/root: sysadmin's "home".
/sbin: software mostly used by the system like fsck = filesystemcheck.
/sys: status of system processes.
/tmp: temporary stuff like opening a pdf from internet for reading,emptied on reboot.
/usr: user installed software including libs and files like themes etc.
/var: log files and a lot more.
This is of course not a complete list.
What makes Linux so safe is the way a user's program is run.
When you start a program as user it is loaded into RAM and the rights are changed to the user's rights.
IOW that program can never change anything outside the user's rights.
An intruder can only change things to which the user is entitled,nothing else.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Fri Mar 18, 2011 12:11 pm  (#17)
Interesting setup :)
Thanks for explaining it in detail.
PC maybe you should get some sleep :lol
PostPosted: Sat Mar 19, 2011 7:19 am  (#18)
Try this website - http://sourceforge.net/userapps/mediawi ... =Downloads
They may have the platform install you need i am not sure though.I think this is it?
http://downloads.sourceforge.net/gtk-wi ... m?download
If they do, uninstall GTK runtimes first and re-install theirs so you avoid conflicts.
Then install the themes package.
PostPosted: Sat Mar 19, 2011 7:25 am  (#19)
You may want to check and make sure you do not already have it installed in Linux distros.
Look in GTK runtimes folder for gtk2_prefs program.
PostPosted: Tue Jun 09, 2015 12:26 am  (#20)
ok - and where do i finde Themesnfor Mac?
