It is currently Wed Oct 28, 2026 6:37 pm
 Post subject: Any Mint users out there?
PostPosted: Mon Feb 22, 2016 9:09 am  (#1)
http://www.theregister.co.uk/2016/02/21 ... cial_site/
http://www.osnews.com/story/29093/Linux ... _security_
Edit: not their day: http://www.theregister.co.uk/2016/02/22 ... ms_hacked/
 Post subject: Re: Any Mint users out there?
PostPosted: Mon Feb 22, 2016 2:21 pm  (#2)
Thanks Ofnuts for the heads up. I’ve had my system installed for a couple of weeks now and I don't use Cinnamon so it looks like I’m safe.
PostPosted: Mon Feb 22, 2016 2:29 pm  (#3)
I wondered why their site was down when I went net surfing - I use Linux Mint for my music PC.
PostPosted: Tue Feb 23, 2016 1:13 am  (#4)
Thanks Ofnuts! I am running Mint 17.1, so I should be good, but I'm doing some checking anyway...
(Solve if you can ... ;) )
PostPosted: Tue Feb 23, 2016 4:29 am  (#5)
Do not get too worried. It was the cinnamon versions of Mint 17.3 for one day only, 20th, where downloaded .iso files were 're-routed' via Bulgaria.
AFAIK the problem stems from LM's use of WordPress as a host. So, for the moment their user forum and links to the main downloads page are disabled.
The LM blog says that updates are not affected (most come from ubuntu anyway)
Using LM 17.1 ? must never have updated then :) see http://blog.linuxmint.com/?p=2871 as an example.
Desperate for a LM live DVD? The mirrors are still there, use the MATE versions, use the MD5 checksums, check the issue date (before 20th)
example https://ftp.heanet.ie/mirrors/linuxmint ... able/17.3/
Of course if you did download last Saturday, and you have installed it, reformat and start again.
There is a way of checking a DVD, run a 'live' session, look for a file /var/lib/man.cy, then this is an infected ISO.
