It is currently Wed Oct 28, 2026 10:05 am
 Post subject: DosBox
PostPosted: Thu Mar 10, 2016 2:56 pm  (#1)
I was wondering if anyone had any experience using DosBox to run old dos games?
I'm trying to run this old game from 1995 that I have on disk,
but every time I set it up to run.
The game goes through a,
"Game Requirements Detection" and states it has detected that I have 0 (zero) Virtual Memory.
I've tried using the "Freesize" dos command to set the size of the VM for the drive,
but even after doing this it still detects zero virtual memory and I'm unable to install the game.
Here's a screenshot of the games splash screens.
Showing the virtual memory requirements and what's been detected.
Any suggestions?
:puzzled
 Post subject: Re: DosBox
PostPosted: Thu Mar 10, 2016 4:46 pm  (#2)
Only ever used dosbox for this old scrabble and then only in linux
For the memory I have a dosbox-0.74.conf file which contains the section.
[dos]
# xms: Enable XMS support.
# ems: Enable EMS support.
# umb: Enable UMB support.
# keyboardlayout: Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
That gives memory and file values as:
Zero disk space? Are you trying to run off a CD?
Have you mounted the game folder as per the very sparce dosbox help?
best of luck ;)
PostPosted: Thu Mar 10, 2016 5:05 pm  (#3)
[dos]
xms=true
ems=true
umb=true
best of luck ;)
This is what I've managed to do thus far...
1. Added all the files from the CD, to a folder, mounting the C drive and folder as, C C:\folder name.
2. Run command "dir" for the "C: drive", showing the list of files within this drive.
3. Running the command, Install.exe from the c drive folder.
Doing this opened the game's splash screen.
Displaying a message that the game needed to be installed for the disk.
4. placed disk into cdrom drive and mounted the cdrom drive in dosbox.
The same results appear every time without exception, zero virtual memory.
I'm at a loss as to why the drive shows up with zero Virtual Memory, no mater how I run it?
Making the game uninstallable, due to lack of the required virtual memory needed to run the game.
PostPosted: Thu Mar 10, 2016 5:25 pm  (#4)
I have a Win98se VM and, if needed, would run any DOS game in that OS. lol
PostPosted: Thu Mar 10, 2016 5:42 pm  (#5)
if needed,
I've tried to run the game from it's files and the game want's me to install the game using it's disk.
Nonetheless,
here's a link to all the game files for this game.
The game in question is called,
Across the Rhine
All the files are in a zip-folder named ATR and can be downloaded for the link below..
https://www.dropbox.com/s/a6naef4ffpswey4/ATR.zip?dl=0
Note:
Use the "DOWNLOAD" button at the upper right.
PostPosted: Thu Mar 10, 2016 6:24 pm  (#6)
I get an error stating that you can only install the game from the original disks, Wallace (in my Win98se VM that is). :)
PostPosted: Thu Mar 10, 2016 6:25 pm  (#7)
OK; found out you had to install it from the CD rom so installing it now. :)
PostPosted: Thu Mar 10, 2016 6:29 pm  (#8)
You were able to download the files?
You can create a disk from the files.
So that you might be able to run it from disk.
However, I don't know if you're willing to do this.
PostPosted: Thu Mar 10, 2016 6:38 pm  (#9)
OK; was able to install the program but not run since it requires 3000K of EMS memory and I cannot remember how to do the page memory crap nor do I have the desire to re-learn. lol
PostPosted: Thu Mar 10, 2016 6:43 pm  (#10)
What you have experienced is the same thing I'm going through and I can't run this game.
Thanks Lyle for checking it out nonetheless.
PostPosted: Thu Mar 10, 2016 6:51 pm  (#11)
If you know the right switches to enable Expanded memory (it did say it can also use Extended memory which is what Win98 uses, but it wouldn't run in my Win98 VM regardless) in DOSBox and enable CDRom support (apparently, the game still requires that it is in a CDRom), then possibly you can get it to run. Good luck, Wallace. :)
PostPosted: Thu Mar 10, 2016 7:31 pm  (#12)
Thanks Lyle!
PostPosted: Fri Mar 11, 2016 10:40 am  (#13)
Wallace
I downloaded the file and will take a look at it later today. I use to be good with that stuff back in the day. I will see what I can remember.
Can you run VirtualBox? If I am able to get it running in VB, I could just transfer the whole pkg.
PostPosted: Fri Mar 11, 2016 1:03 pm  (#14)
I use DOSbox and am downloading your game to see how far I can get with it. Will comment again soon with my results.
I use a frontend for DOSbox. If you don't use one. then I highly recommend one, as it help you configure everything via a GUI and save your games settings individually. There's quite a few frontends out there for DOSbox. The one I use is called DOSbox Game Launcher:
http://members.quicknet.nl/blankendaalr/dbgl/
PostPosted: Fri Mar 11, 2016 1:35 pm  (#15)
bilbo9955 wrote:
Wallace
Thanks for your help.
I've used VB a while ago and only just started using DosBox.
Good luck.
I don't know what a frontend is.
All this stuff is new to me.
PostPosted: Fri Mar 11, 2016 4:08 pm  (#16)
bilbo9955 wrote:
Wallace
Good luck.
Managed to get it working. Would you like me to upload the file with the fully working installation?
PostPosted: Fri Mar 11, 2016 4:41 pm  (#17)
David-C wrote:
bilbo9955 wrote:
Wallace
Good luck.
Would I?!
Heck yeah!!!
I'm not sure if you can upload all the files here to Gimp Chat, but go for it and let me know if all the files were able to be uploaded.
PostPosted: Fri Mar 11, 2016 5:23 pm  (#18)
Would I?!
Heck yeah!!!
http://www.megafileupload.com/at3x/ATR.tar.gz
To play the game run "game.exe". If you get no sound then exit the game, run "install.exe" and configure your sound from there. Your sound card info is in your DOSbox .config file, so use it as reference when configuring. You will still see the error about no virtual ram, but it doesn't matter.
I'm not familiar with the game, but it just seems to generate a map and automatically start up. There's no menus to choose any missions etc...
PostPosted: Fri Mar 11, 2016 5:42 pm  (#19)
David-C wrote:
Would I?!
Heck yeah!!!
Thanks David-C for taking the time to put this together for me.
I'll give it a try to see how it goes.
Thanks again. :bigthup
