It is currently Wed Oct 28, 2026 10:04 am
 Post subject: Need Help with PhotoFont Plugin [SOLVED]
PostPosted: Thu May 05, 2016 8:53 pm  (#1)
Does anyone know how to create,
compile and or edit the .phf files.
Used with this PhotoFont plugin?
I'm trying to create the .phf file for a particular set of images.
To be use by this plugin and need to create the .phf file for these images,
for use with the PhotoFont plugin.
Any information that can be provided will be greatly appreciated.
Thanks Wallace.
 Post subject: Re: Need Help with PhotoFont Plugin
PostPosted: Thu May 05, 2016 9:16 pm  (#2)
Believe it was Rod that figured all this out, but it's been a while since I saw him post here. Believe he posted the how in a thread here (just too lazy to find it Wallace). :)
PostPosted: Thu May 05, 2016 10:06 pm  (#3)
I've look at most of what I can find in reference to this topic here on GC,
but haven't found any way to create a PHF file that works. :(
PostPosted: Thu May 05, 2016 10:29 pm  (#4)
Maybe the link below will help. :)
viewtopic.php?f=12&t=3581
PostPosted: Thu May 05, 2016 11:07 pm  (#5)
i looked at that file format a little. maybe you can hack it a little
thinking maybe you can copy an existing .phf file (like download a free .phf font)
open it up in a text editor.
then copy image data encoded in base64 and decode it
using this site.
http://www.motobit.com/util/base64-deco ... &acharset=
just copy after the 2 lines that says ...
Content-Type: image/png; charset=US-ASCII; name=Image0000.png
Content-transfer-encoding: base64
It might say something else for each imagename
and starting at the beginning of blank line after these two lines copy to the beginning of the next closing image tag (</image>)
and choose decode into binary file and name it something.png.
and open that up in Gimp and edit it to your liking
I got that far I am assuming you can just draw your own images over their images and then convert it back to base64 and paste that in to their .phf file.
and try that out.
I opened up some .phf file some smaller res files only uses/defines one image.
Other highres file files define many images so you'll have to decode and encode many of them.
PostPosted: Thu May 05, 2016 11:12 pm  (#6)
Thanks Lyle. :bigthup
I've looked over everything I could find on this topic,
but still come up empty and can't compile the needed PHF file.
using this site.
and try that out.
Thanks Tin.
You make it all sound easy.
I can't figure out what it is I'm suppose to do.
I have all the images, I just need to make the PHF file for them.
PostPosted: Fri May 06, 2016 12:02 pm  (#7)
I sorta created a hacked process.
try this and see if it works. This is for windows...might work in linux i don't know.
1) Have Python 2.7.11 installed.
2) Have openssl installed from here http://gnuwin32.sourceforge.net/packages/openssl.htm (I just used the first setup link. My Python script will call openssl command to decode and encode base64 the png files/data.
3) add the path to openssl to environment variables so that openssl can be called from anywhere, I added C:\Program Files (x86)\GnuWin32\bin to my environment PATH.
4) download this file and extract it to some folder the same as your free downloaded .phf file, it'll be named test.py
test.zip [921 Bytes]
Downloaded 181 times
5) in a command prompt, run
python test.py
it 'll ask you to enter a name of a .phf file (enter the full filename)
then I'll give you 2 choices 1 or 2
enter 1
1 will extract all the .png file(s) from the .phf file and dump it to the same folder.
This process decodes from base64 to png files
6) now go check out the png files and overwrite them, edit them or whatever.
7) when you're done editing png files.
run python test.py again, enter the same .phf file name
and choose choice 2
This process will now encode the png files into base64 and put them along with .phf original information into a file with the same name as the original .phf file except with a ".new" appended to the end of file name...
you can then rename this file to .phf file your your choice .
Try it out and let me know if this hack works for you.
PostPosted: Fri May 06, 2016 12:18 pm  (#8)
test.zip
python test.py
enter 1
and choose choice 2
Thanks Tin. :bigthup
I did it just as you described, but when installing the PHF file.
Photofont says that the PHF file is invalid.
PostPosted: Fri May 06, 2016 1:38 pm  (#9)
which plugin are you using maybe i'll try to install it myself to observe what's wrong with my output file
PostPosted: Fri May 06, 2016 1:41 pm  (#10)
I'm using the Photofont plugin.
:roll:
PostPosted: Fri May 06, 2016 1:44 pm  (#11)
where did you get it? can you link me to it? i tried going to some link and it's broken from this gimpchat forum so i don't know where to get it.
PostPosted: Fri May 06, 2016 1:58 pm  (#12)
the link works, i just had to sign in to drop box.
so what do i do with these files drop them in my gimp's plugin folder?
I think you linked me the wrong .zip i only see .phf files and no .exe's
PostPosted: Fri May 06, 2016 2:08 pm  (#13)
Yes that was the wrong file. :oops:
Here's the correct file link... https://www.dropbox.com/s/ts2y630qro44p ... i.zip?dl=0
The PSPI.exe goes into you Gimp plugins folder.
The pspi.exe allows you to use PhotoShop plugins with Gimp.
The PhotoFont.exe needs to be installed. Once it's installed. It will show up as PhotoFont Start in your list of installed programs.
Before you install it, you first need to create a folder named Photoshop Plug-In, in you Gimp User folder.
When you install PhotoFont it will ask you where to install it. You will need to install the plugin into the new Photoshop Plug-In folder you made. The photofont installation file in named ps2win.exe.
You also need to configure the PSPI plugin, so that it will look for PhotoShop plugins in the new Photoshop Plug-In you made in your Gimp User folder.
PostPosted: Fri May 06, 2016 2:10 pm  (#14)
i'll try and see what happens...i am determined to get this hack using existing .phf to work
PostPosted: Fri May 06, 2016 2:13 pm  (#15)
MareroQ seemed to figure it out rather quickly.
Thanks and good luck. :bigthup
PostPosted: Fri May 06, 2016 2:18 pm  (#16)
You also need to configure the PSPI plugin, so that it will look for PhotoShop plugins in the new Photoshop Plug-In you made in your Gimp User folder.[/align]
I did everything except this step...how do i do it?
In Gimp I tried to look for PSPI or PhotoFont and nothing showed up so I don't know what to do next.
PostPosted: Fri May 06, 2016 2:24 pm  (#17)
never mind i see it.
and got PhotoFont to start.
Now i just gotta find out why it's invalid
PostPosted: Fri May 06, 2016 2:36 pm  (#18)
Too late... :hehe
If you installed the PSPI.exe into your plugins folder, it should show up in filters.
Create a new folder named Photoshop Plugins, in your Gimp User folder.
Configure PSPI to look for this new folder.
PostPosted: Fri May 06, 2016 3:01 pm  (#19)
Is PhotoFont Free? I have the file downloaded, I just haven't installed it.
PostPosted: Fri May 06, 2016 3:05 pm  (#20)
mackenzieh wrote:
Is PhotoFont Free?
Yes it's free, but it's not easy to find.
