It is currently Sat Oct 31, 2026 5:55 pm
 Post subject: Here's how to reset Edge.
PostPosted: Wed Jul 27, 2016 10:15 pm  (#1)
I had a weird issue when I repaired my Win10 install. Edge would launch extremely slowly. Doing a bit of searching, I ran across the thread below:
https://social.technet.microsoft.com/Fo ... progeneral
Mr. Happy's solution worked, but seemed ridiculous that you have to do this to reset Edge to it's defaults (of course doing this means you literally loose everything to do for your browser including your favorites, so back those up before doing this).
First you need to delete the following folder:
C:\Users\%username%\AppData\Local\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe
Note once I deleted the folder, the folder was still there so deleted it again, then it was gone.
Of course your edge will no longer work.
Now, run powershell as administrator and type the following command:
Get-AppXPackage -AllUsers -Name Microsoft.MicrosoftEdge | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml" -Verbose}
Launch edge (will be slow at first launch) and then all was well when I closed and relaunched. Now I have the new car smell for both my Win10 OS and Edge.
Still, I usually use my Virtualbox Win XP for browsing but do occasionally (at risk to me) use Edge. lol
