It is currently Wed Nov 04, 2026 1:52 am
 Post subject: Tech ? again. [Solved]
PostPosted: Fri Sep 16, 2016 7:41 am  (#1)
Has any one here heard of pkf files, and are there any free downloadable programs for them?
 Post subject: Re: Tech ? again.
PostPosted: Fri Sep 16, 2016 7:55 am  (#2)
never heard, but googling I found:
What is a PKF file?
Peak file created by Adobe Audition, an audio production application; contains waveform data related to a specific .WAV file; generated automatically when an audio file is opened or imported.
More Information
PKF files provide a visual display of the waveform within an audio file. Once a PKF file has been generated, the waveform does not need to be re-rendered each time the audio file or corresponding project file is opened.
NOTE: The PKF format was introduced in Adobe Audition CS5.5. It is similar to the .PK format used by previous versions of Audition, but contains floating-point data and can display waveform data for audio signals above 0dB. Since PKF files use a newer file format than PK files, they are only recognized by Audition CS5.5 and later.
PostPosted: Fri Sep 16, 2016 8:06 am  (#3)
Thanks, done all that and found that as well. Apparently it is a professional program format. Maybe they use it in Universities? Hoping maybe some one will find what I haven't.
Of course they would say they don't know of any other programs that could open it....But why would they when they can sell the original program.
PostPosted: Fri Sep 16, 2016 8:08 am  (#4)
but it's in any case an "audio" format, not for images
edit: you've probably seen also
▶ Need to open a .PKF file? Try File Viewer Plus
did you try it?
PostPosted: Fri Sep 16, 2016 8:13 am  (#5)
Yes I know. Didn't know who else to ask. If no one here can tell me any thing about it I will have to ask the poster of this file if they can put it in another format.
Thanks again for trying. :)
No I haven't tried it. Saw it but didn't want the add ons it comes with
PostPosted: Fri Sep 16, 2016 10:44 am  (#6)
Could be "Product Key Finder"
http://www.product-key-finder.com/pkf-installed.html
PostPosted: Fri Sep 16, 2016 10:47 am  (#7)
It may open with Adobe Reader also.
PostPosted: Fri Sep 16, 2016 12:06 pm  (#8)
Which version? I had 8 and it wouldn't open and just updated to DC and it still wouldn't.
PostPosted: Fri Sep 16, 2016 12:27 pm  (#9)
.pkf as used by Adobe Audition is an image file:
https://www.youtube.com/watch?v=tnipXPa_AnI
But it's an image of an audio waveform that's only used by Audition to save time, so it's very unlikely that any other software has been written to decode it.
Kevin
PostPosted: Fri Sep 16, 2016 12:47 pm  (#10)
All fixed!
I didn't even have to ask him to change the format. It is now in MP3. I think most people would have that. What I wanted to listen to was an interview - Genocide in Vietnam
Thanks for every one for looking and letting me know how I could or could not open it. :)
PostPosted: Fri Sep 16, 2016 1:39 pm  (#11)
sallyanne wrote:
All fixed!
Good deal. Glad you got it sorted. :clap
