It is currently Sun Oct 11, 2026 9:56 pm
 Post subject: GAOTD has a cool program today but....
PostPosted: Fri Jan 13, 2017 6:57 am  (#1)
...all I've heard from the comments were complaints (read them yourself) so buyer beware. lol
Though I would like this program myself, I'll pass, but maybe some of you more adventurous types might bite (and hopefully not crash their PCs). :)
https://www.giveawayoftheday.com/style/
 Post subject: Re: GAOTD has a cool program today but....
PostPosted: Fri Jan 13, 2017 8:43 am  (#2)
Downloaded and installed into Windows 10 64 bit
Settings
Results took 25 minutes or so to render.
PostPosted: Fri Jan 13, 2017 9:12 am  (#3)
ASCII Empty same settings
This also took exactly 25 minutes.
Just a heads up Lyle.
Your images are auto saved into Users/USERNAME/Pictures/Style folder
PostPosted: Fri Jan 13, 2017 9:15 am  (#4)
Seems way too slow, Rod. I'll wait until David figures out how to coax G'MIC to transfer styles (yes; David's looking into it). :)
PostPosted: Fri Jan 13, 2017 9:25 am  (#5)
Sounds good to me Lyle i would rather not use this software. It really consumes your RAM. So i will probably do all the styles and see if i like any particular ones. If not i will uninstall it.
PostPosted: Sun Aug 19, 2018 3:16 am  (#6)
OK; Style at GAOTD is back. Yes; it still will crash on images not much bigger than 1500px on my system (so 1024px I use then uprez), but still, the results are very unique and worth the install. I did so last time (said I wouldn't but did; no regrets. I just know the limitations when it comes to my horse (PC that is). lol). :)
https://www.giveawayoftheday.com/style-2-2-0-4-win-mac/
PostPosted: Sun Aug 19, 2018 4:51 am  (#7)
Style: John Constable
ref: http://www.fontplay.com/freephotos/thir ... 108-21.jpg
OK; it's 4:49am and I'm about to head off to work in a bit for a 14 hour. It is what it is. lol
I admit I had to add all kinds of embellishments with this result since, for starters, I had to uprez it and also, this style doesn't play well with horizons and skies. :)
https://www.flickr.com/photos/34520999@ ... 8/sizes/o/
PostPosted: Sun Aug 19, 2018 10:07 am  (#8)
Got it.
Which effect(s) do you like better, Lyle?
(w/o any pre-post-process, except downscaling not to wait a lot)
PostPosted: Sun Aug 19, 2018 10:22 am  (#9)
Nice result Lyle, I dig it.
PostPosted: Sun Aug 19, 2018 10:23 pm  (#10)
Thanks Warrior.
To answer Diego, I like the more goofball like ones, such as outline. Don't really have a favorite preset, though. :)
PostPosted: Sun Aug 19, 2018 11:13 pm  (#11)
In general, having tried all effects -except ASCII- both using and not using image colours, I feel quite disappointed.
Oil painting has nothing to do with oil painting, same for watercolour, same for pointillism,....
It looks like a software initiated then suspended by the author when he/she was at 20% of the definitions of the goals and the methodology.
But -as ancient Romans said- de gustibus non disputandum est.
PostPosted: Mon Aug 20, 2018 3:53 am  (#12)
Come on, Diego; you need to embrace the DMT and your 3rd eye. lol
PostPosted: Mon Aug 20, 2018 4:47 am  (#13)
Took Psychodelic preset, and massaged it with both the original image and with G'MIC and FotoSketcher and this is what came of it. I see the potential of things, Diego. I never take output from filters at face value. I just look at filters as tools to be exploited. :)
PostPosted: Fri Aug 24, 2018 6:57 pm  (#14)
I like that last one a lot, Lyle.
PostPosted: Fri Aug 24, 2018 10:25 pm  (#15)
Thanks, Pat. :)
PostPosted: Mon Aug 27, 2018 6:21 am  (#16)
Last one looks like a good outcome but I can understand you wanting to exploit the filters and find out just exactly how much they can do
PostPosted: Mon Aug 27, 2018 6:41 am  (#17)
Ya, Lyle and me have different approaches to filters.
For me, a released filter has to provide a good outcome just using the default set-up.
It is (was) my objective also when producing my own filters: if a tester finds they produce not nice results using defaults, I modify it before (or just after) releasing it.
Afterwards (i.e. if the first condition is met), it could be nice to exploit variations with post-processing steps.
In the case of "Style", I did run it in all pre-sets, with and without image colours, and 90-95% of results were bad IMO. This is not what I would expect from a filter which takes a so loooong time to produce an outcome.
PostPosted: Mon Aug 27, 2018 8:47 am  (#18)
In my younger retouch days, I was pursuing the dream that a single filter/script could give you a masterpiece Diego. I stopped that pursuit years ago. Some exceptions of course like the Engrave preset (G'MIC) which can pretty much give you a single click artistic result. Regardless, I look at all plugins/script as tools; brushes if you will. To each his/her own. :)
