It is currently Fri Oct 16, 2026 10:22 am
 Post subject: Windows Cortana
PostPosted: Fri Mar 10, 2017 5:36 am  (#1)
Does anyone know how to get rid of this. I'm sure i don't use it and only noticed today looking at my task manager just after turning my lap top on, being idle it was still using a lot of cpu!
I just looked online and it seems it cannot be disabled.
 Post subject: Re: Windows Cortana
PostPosted: Fri Mar 10, 2017 7:34 am  (#2)
Possible solution: https://www.howtogeek.com/265027/how-to ... indows-10/
Sure-fire solution: https://help.ubuntu.com/community/Installation
PostPosted: Fri Mar 10, 2017 7:41 am  (#3)
When idle, Cortana uses 0% of CPU (it only occupies Memory)
PostPosted: Fri Mar 10, 2017 8:20 am  (#4)
@ ofnuts. lol yes, I am going to do something like that but when I get a new computer. :) Thanks for the links.
@ dinasset I went back and had a look and mine was using the cpu not memory. :) By idle I meant I hadn't turned on the internet yet. No other programs except what comes on at startup. Might be because it was still starting up? Anyway I don't want it and I have looked around, most people are unhappy with the addon/app which was thrust upon us with windows 10.
I was hoping it was a program that I could delete but it not in the programs list.
PostPosted: Fri Mar 10, 2017 8:27 am  (#5)
ofnuts wrote:
Unfortunately, MS stopped that hack to the registry, it no longer works.
PostPosted: Fri Mar 10, 2017 8:49 am  (#6)
Wit the "pro" version, the "policy" hack should still work (otherwise there would be a lot of very powerful and irate corporate customers).
A solution is to rename the executable, but it's a bit radical (and breaks local search as well).
PostPosted: Fri Mar 10, 2017 9:59 am  (#7)
Sallyanne, I think you're right to wait until you have a new computer.
On my PC every time I click CtrAltCanc (IT) to get the list of running activities, Cortana occupies 0% CPU; my PC is approx one year old. I've always the internet connection active. Cortana comes on only when clicking on bottom left Win key (then Cortana says: "ask me something", but I do not use it)
PostPosted: Fri Mar 10, 2017 11:10 am  (#8)
Here's another link to howtogeek.com.
At the bottom of this post.
Explaining why after disabling Cortana,
it's still running in the background and How-to geek's solution.
I disabled it,
as well as the Indexing service and reamed the folder,
Microsoft.Windows.Cortana_cw5n1h2txyewy.
Wherein lies the SearchUI.exe related to Cortana.
By adding an additional "Y" to the end of the folder name.
As you can see from my Task-manager screenshot,
Cortana is no longer showing up in my Task-manager.
It also doesn't run in the background any longer.
I've confirmed this by running the program Autoruns and anything related to Cortana,
isn't running any longer.
Why Is Cortana Still Running in the Background After You Disable It?
PostPosted: Fri Mar 10, 2017 11:41 am  (#9)
Thank you everyone for your answers. :)
PostPosted: Fri Mar 10, 2017 11:54 am  (#10)
Don't you find it weird that we are now in a time where computers are really evolving backwards and people cling to their existing stuff as long as they can (be it WinXP, Win7, the last version of the MacBook Pro where you can still change the batteries, the last waterproof Moto G that fits in a pocket...). All the new stuff I have seen recently has very little added value for me and a lot of added value for the company that sells it.
In the same distressing vein, a linguist doing a study of words frequency in Google docs found that we are no longer talking about "progress" but only of "innovation", and this happened at the same time in all western languages (French, English...). In Russian it happened after the fall of the Iron Curtain. For thos who read French: http://www.pourlascience.fr/ewb_pages/a ... -38081.php
PostPosted: Fri Mar 10, 2017 1:15 pm  (#11)
Ofnuts, your underlined change in wording (from "progress" to "innovation") is unfortunately true also in the human relationships: a lot of "innovations" but no more "progresses", alas!...
PostPosted: Fri Mar 10, 2017 1:43 pm  (#12)
It seems to be the same case,
when it comes to Intel CPU's.
PostPosted: Fri Mar 10, 2017 3:25 pm  (#13)
I did the registry hack when Windows 10 first came out. It's still working fine on my AMD machine with Windows 10 Home Edition. Cortana went on a permanent vacation! :hehe
