It is currently Sat Oct 17, 2026 2:31 pm
 Post subject: I want to share your artwork!
PostPosted: Sun Apr 08, 2018 5:47 pm  (#1)
Former Member
As some of you may know I'm building a course on graphic design in my free-time.
There's a part of the course that goes over colors. One part of this section I go over different color schemes. This is the part on the course I want to use to help give light on 6 great artists using free software by showcasing some great artwork utilizing 6 different color schemes.
Requirements:
The design must be made using ONLY free software
Must have a deviantART, Behance or Instagram (maybe exception on others, this is cause I will add a QR code to the image if not already on so the viewer can go and view your portfolio)
The resolution of the image MUST be at least 1920x1080
I already have a design for the Monochromatic color scheme. Here are the remainder color schemes I'm looking for.
Analogous
Complementary
Split Complementary
Triadic
Tetradic
Neutral
I can easily design all my own content but I really want to help get others in my course. So if you have a design that fits the requirements. Reply here or send me a DM of it. (Doesn't have to be GIMP artwork, just had to be made in free software)
I will say that most of the artwork in the course are animated vector graphics so if your design is vector based it has a higher possibility of being featured to match the other content on the video.
 Post subject: Re: I want to share your artwork!
PostPosted: Mon Apr 09, 2018 1:23 am  (#2)
With your money obsession I wonder if you just want to exploit other peoples talent to line your own pockets?
PostPosted: Mon Apr 09, 2018 1:27 am  (#3)
http://www.gocomics.com/wtduck/2018/04/07
PostPosted: Mon Apr 09, 2018 2:10 am  (#4)
lol :)
